4.0" touch screen - Universal GRBL CNC pendant to control DIY GRBL CNC machines. up to 4 axes
This Universal GRBL CNC pendant is designed to control DIY GRBL/FluidNC CNC machines. up to 4 axes FEATURES: Colour 4.0" touch screen embedded ESP32E 4 M=32mbit TTL serial port (on USB A slot)…
Read More…This Universal GRBL CNC pendant is designed to control DIY GRBL/FluidNC CNC machines. up to 4 axes
FEATURES:
GRBL
GRBL has been adopted by the majority of hobbyist CNC, many software can design and deliver Gcode files.
You can use our latest 6 PACK COMPACT GRBL32 CNC controller (version >D without adapter or version C with some few wiring) or any GRBL CNC controller with TTL serial or Bluetooth or WiFi (TELNET) connection.
This controller uses the latest ESP32-32E 32 bits fast MCU 240MHz with 4MByte memory. Embedded web server and web application give easy control of your pendant using any browser on a computer, a smartphone or a tablet, while a USB serial keeps available for wired connection.
Firmware
This is a powerful CNC pendant for any CNC based on GRBL /FluidNC. It has moved far beyond Grbl though taking full advantage of the dual-core, 32-bit, 240Mhz processor. It also has built-in Bluetooth and WiFi, with a web server and web application.
Firmware is open source and will be on GitHub soon
We also offer Open source 3D print (stl) enclosure ON THINGIVERSE here
WHAT IS INCLUDED
ORDERING Please note that this item is provided WITHOUT CNC controller, those are available in our Shop
You may have a look at ou kit here and save some cost
Enter your email address if you'd like to be notified when 4.0" touch screen Universal GRBL CNC Pendant can be shipped to you:
$105.00
$33.00
$41.00
$6.50
$95.00
$105.00
$41.00
