ESP32_grbl CNC I/O Module with 4 switch inputs with opto isolated inputs and isolated power supply
What is it? This is an input CNC I/O Module designed for use with the 6 Pack Universal CNC Controller. It is used for switch inputs. It can use simple mechanical switches, opto interrupt switches, so…
Read More…This is an input CNC I/O Module designed for use with the 6 Pack Universal CNC Controller. It is used for switch inputs. It can use simple mechanical switches, opto interrupt switches, some proximity switches, Hall effect sensors, etc. The inputs would be used for limit/homing switches, probe, control switches and macro buttons.
This is our original PCB design, based on Bart Dring with some minor changed to adapt to our need.
DESCRIPTION This module is 100% compatible with Bart DRING module : It has a 3 position terminal block per switch input (Signal, +5V and Gnd). Offering optoisolated inputs with an isolated power supply. To improve the signal is also filtered and sent through a Schmitt trigger. Dealing with noise and voltage spikes is a huge problem with CNC machines, this optocoupled module solve this.
WHAT IS INCLUDED
ORDERING
Please note that this item is to use with our 6 pack compact modular controller available in our Shop
Enter your email address if you'd like to be notified when 4x Input CNC I/O module can be shipped to you:
$105.00
$33.00
$41.00
$6.50
$4.95
$210.00
