UNIVERSAL STEPPER MOTOR DRIVER "POLOLU" A4988 FOR YOUR 3D PRINTER OR CNC
Sold By SmartElectronic
This is one of the most basic stepper motor controllers also know as "POLOLU" Compatible with 3D printers: Prusa Mendel, Ultimaker, Rostock(delta), Printbot, Makerbot It's an essential module to stru…
Read More…This is one of the most basic stepper motor controllers also know as "POLOLU" Compatible with 3D printers: Prusa Mendel, Ultimaker, Rostock(delta), Printbot, Makerbot It's an essential module to structure a 3d printer, engraving machines or small CNC
This breakout board for Allegro’s A4988 microstepping bipolar stepper motor driver features adjustable current limiting, over-current and over-temperature protection, and five different microstep resolutions (down to 1/16-step).
It operates from 8 V to 35 V and can deliver up to approximately 1 A per phase without a heat sink or forced air flow (it is rated for 2 A per coil with sufficient additional cooling). This board ships with 0.1″ male header pins
Specifications: This product is a carrier board or breakout board for Allegro’s A4988 DMOS Microstepping Driver with Translator and Overcurrent Protection. This stepper motor driver lets you control one bipolar stepper motor at up to 2 A output current per coil
Here are some of the driver’s key features:
Simple step and direction control interface Five different step resolutions: full-step, half-step, quarter-step, eighth-step, and sixteenth-step Adjustable current control lets you set the maximum current output with a potentiometer, which lets you use voltages above your stepper motor’s rated voltage to achieve higher step rates Intelligent chopping control that automatically selects the correct current decay mode (fast decay or slow decay) Over-temperature thermal shutdown, under-voltage lockout, and crossover-current protection Short-to-ground and shorted-load protection This product ships with all surface-mount components—including the A4988 driver IC—installed as shown in the product picture.
This product ships individually packaged with 0.1″ male header pins included
WHAT IS INCLUDED
1 x A4988 stepper motor drive module 1 x aluminium dissipator
ORDERING
Please note that this item is ONLY stepper controller YOU NEED A BOARD WITH MCU TO DRIVE A STEPPER MOTOR You can use our 6 pack compact CNC controller available in our shop
Enter your email address if you'd like to be notified when A4988 Stepper Motor "Stepstick" Driver "Pololu" can be shipped to you:
$105.00
$33.00
$41.00
