BlueStim - a Stereo Estim box in a Pocket size
ADULT ONLY Provided that you are at least 18 years old, long-time ESTIM practitioner This production is made for electro-stimulation based on specific sound track IMPORTANT DISCLAIMER This product ha…
Read More…ADULT ONLY Provided that you are at least 18 years old, long-time ESTIM practitioner
This product has been developped for DIY E-Stim only and ESTIM practitioner
no waranties about any expected results are provided,
We do our best to provide a safe design but we cannot be responsible about anything happen
USE THIS AT YOUR OWN RISK
It is an autonomous 3 in 1 pocket stereobox with its own amplifier: Bluetooth, USB/SD card reader, sound card Play a sound track and enjoy stimulation.
Features:
Two adjustable resistor limit (restrict) the level sended to amplifier - change setup at your own risk -
With this restriction set to 50% and a load of 500 Ohm (equivalent to a wet body) and the volume at full volume
Estimated operating time : around 4 hours theoretically on a 2000 mA pack and more probably 3 hours in a real situation depending on real usage. Once again, you can mount two batteries in the case and/or use an external pack to increase the operating time (if necessary)
For security the Max current is limited to 50 mA each channel by resetable PTC fuses
The board is finished, nothing needs to be soldered!
As you can see in the photo there are connectors (pin) with standard pitch 2.54 to be able to directly connect your probe cables if you do not want to use the 2.5 jacks If you prefer you can use these pins with a switch then you can make a three-phase mode
Between the Bluetooth block and the transformers there are also pins (red and green jumper on the picture) either to directly control each transformer or to add a 2x3 way switch and make a left/right inverter
Enclosure can be provided (option) Sterolitographic 3D printed else we also provide free STL files you can print by yourself here : here
Links to code and documentation Design Files :thingiverse.com
Enter your email address if you'd like to be notified when BlueStim - Stereo Estim box in a Pocket size can be shipped to you:
$105.00
$33.00
$41.00
$6.50
