Small rotating display 5 volts with USB adapter
Sold By SmartElectronic
This is a small rotating display I use for my DIY UV curing station You can Diameter 14 cm Height 4.3 cm Power : 1 W Rotating speed: about 30 sec / turn direction : direct /inverse by select switch M…
Read More…This is a small rotating display I use for my DIY UV curing station You can Diameter 14 cm Height 4.3 cm Power : 1 W Rotating speed: about 30 sec / turn direction : direct /inverse by select switch Material : ABS Max load : about 3 kg Power supply = 5 volts DC Rotation : embedded electric motor
Included : USB cable - charger not included
My tips : you can get my UV panel here : https://www.tindie.com/products/37166/
Enter your email address if you'd like to be notified when Display turntable can be shipped to you:
$105.00
$33.00
$41.00
$24.80
$59.95
$13.85
