UNIVERSAL STEPPER MOTOR DRIVER "POLOLU" DRV8825 High Current, FOR YOUR 3D PRINTER OR CNC
Sold By SmartElectronic
This is one of the most basic stepper motor controllers also know as "POLOLU" Compatible with 3D printers: Prusa Mendel, Ultimaker, Rostock(delta), Printbot, Makerbot It's an essential module to stru…
Read More…This is one of the most basic stepper motor controllers also know as "POLOLU" Compatible with 3D printers: Prusa Mendel, Ultimaker, Rostock(delta), Printbot, Makerbot It's an essential module to structure a 3d printer, engraving machines or small CNC
This breakout board for TI’s DRV8825 microstepping bipolar stepper motor driver features adjustable current limiting, over-current and over-temperature protection, and six microstep resolutions (down to 1/32-step). It operates from 8.2 V to 45 V and can deliver up to approximately 1.5 A per phase without a heat sink or forced air flow (rated for up to 2.2 A per coil with sufficient additional cooling). The driver has a pinout and interface that are nearly identical to those of our A4988 stepper motor driver carriers, so it can be used as a higher-performance drop-in replacement for those boards in many applications. This board ships with 0.1″ male header pins included
Specifications:
This product is a carrier board or breakout board for TI’s DRV8825 stepper motor driver; we therefore recommend careful reading of the DRV8825 datasheet before using this product. This stepper motor driver lets you control one bipolar stepper motor at up to 2.2 A output current per coil ).
Here are some of the driver’s key features:
WHAT IS INCLUDED
1 x DRV8825 stepper motor drive module
ORDERING
Please note that this item is ONLY stepper controller YOU NEED A BOARD WITH MCU TO DRIVE A STEPPER MOTOR You can use our 6 pack compact CNC controller available in our shop
Enter your email address if you'd like to be notified when DRV8825 Stepper Motor "Stepstick" Driver "Pololu" can be shipped to you:
$105.00
$33.00
$41.00
$199.00
