High power UV purple light board 24V 12W aluminum substrate UV curing light board gold wire LED lamp beads
Sold By SmartElectronic
This is a high power UV purple light board for DIY Curing station 24V 12W aluminum substrate for heat dissipation and keep long life LED gold wire LED lamp beads Just connect red and black wire to i…
Read More…This is a high power UV purple light board for DIY Curing station 24V 12W aluminum substrate for heat dissipation and keep long life LED gold wire LED lamp beads Just connect red and black wire to illuminate
I use those to make a DIY curing station for my SLA resin 3D printer using a turntable to rotate the printing and cure in best way
My tips :
I use 4 of those for fast curing in my configuration but a big majority of curing station use only about 24W so 2 panel can be probably enough
You can get the turntable here : https://www.tindie.com/products/37167/
Enter your email address if you'd like to be notified when High power UV curing light board can be shipped to you:
$105.00
$33.00
$41.00
