24V OEM titration laboratory mini peristaltic pump hose drip constant flow water pump self-priming pump gear pump
Sold By SmartElectronic
What is it? This is a peristaltic pump that can be used to move any liquid in a pipe. How it works: A peristaltic pump functions by creating a vacuum inside of the tube, which then draws the liquid i…
Read More…This is a peristaltic pump that can be used to move any liquid in a pipe.
How it works:
A peristaltic pump functions by creating a vacuum inside of the tube, which then draws the liquid into the tube and out the other end.
Advantages:
Easy to operate:
To operate simply apply DC POWER to the two leads located at the bottom of the motor and it will begin to suck fluid from one side and force it to the other.
Recommendation:
This pump comes with food-grade tubing by default but, be sure to sanitize any tubing you receive before use.
ORDERING
Pay attention to select the right voltage (12v or 24v) Those pumps are the same size but can be offered in a different colour, please confirm which colour you need (green is the default) depending on the tubbing pump can offer different min/max pumping volume (check chart), please confirm tubing you need (
Enter your email address if you'd like to be notified when Peristaltic Pump 12V / 24V can be shipped to you:
$105.00
$33.00
$41.00
$200.00
$70.00
$100.00
$180.00
