ESP32_grbl CNC I/O Module 20 Amp RELAY
What is it? This a relay CNC I/O Module designed for use with our 6 Pack compact CNC Controller. You can be used to turn on/off spindles, vacuums, coolant devices, control valves, etc. Why did you m…
Read More…This a relay CNC I/O Module designed for use with our 6 Pack compact CNC Controller. You can be used to turn on/off spindles, vacuums, coolant devices, control valves, etc.
This is our original PCB design, based on Bart Dring with some minor changed to adapt to our need.
DESCRIPTION This module is 100% compatible with Bart DRING module : It offers a 3 position terminal block (NC, NO and common).
WHAT IS INCLUDED
ORDERING
Please note that this item is to use with our 6 pack compact modular controller available in our Shop
Enter your email address if you'd like to be notified when Relay CNC I/O module can be shipped to you:
$105.00
$33.00
$41.00
$6.50
$18.90
