ESP32_grbl CNC I/O RS485 Modbus CNC I/O Module for use with Spindle VFDs
Designed by SmartElectronic in ChinaNo shipping info available.
What is it? This an RS485 Modbus CNC I/O Module designed for use with the 6 Pack Universal CNC Controller. It can be used to control RS485 spindle VFDs. The current firmware supports Huanyang spindl…
Read More…This an RS485 Modbus CNC I/O Module designed for use with the 6 Pack Universal CNC Controller.
The current firmware supports Huanyang spindles with both the original and newer protocols.
RS485 Control is very robust and allows both precise speed control as well as direction control. The firmware constantly monitors the performance of the spindle and can stop your job if the spindle working properly.
This is our original PCB design, based on Bart Dring with some minor changed to adapt to our need.
DESCRIPTION This module is 100% compatible with Bart DRING module : It has a 3 position terminal block
WHAT IS INCLUDED
ORDERING
Please note that this item is to use with our 6 pack compact modular controller available in our Shop
Enter your email address if you'd like to be notified when RS485 CNC I/O Module can be shipped to you:
$105.00
$33.00
$41.00
$79.99
$41.50
$399.00
