TERMINAL EXTRACTOR: Effortless Terminal Removal-Removes terminal wires
Sold By SmartElectronic
Simple to apply - Just insert, push, and pull the wire out instantly without damaging the pins & wires! Even more effective than prying connectors apart with a screwdriver! Effortless Terminal Remov…
Read More…Simple to apply - Just insert, push, and pull the wire out instantly without damaging the pins & wires! Even more effective than prying connectors apart with a screwdriver!
Effortless Terminal Removal-Removes terminal wires from the connectors without causing any damage.Easy to Use
No need to pry the terminals! just insert our tool, push and pull the terminal pins for removal. Our tool provides extra leverage so you can easily remove the wire.
Universal Offers single, double-pin extractors and casting tools of different sizes to fit any terminal.
High-Quality Material Made of premium steel spring plate + plastic. It is flexible and durable.
Wide Applications For most connector terminals which can be used for most cars, motorcycles, and other electronic devices (such as household appliances).
11pc KIT
18pc KIT
38pc KIT
Enter your email address if you'd like to be notified when Terminal Ejector Kit can be shipped to you:
$105.00
$33.00
$41.00
$6.50
$181.39
$12.50
