24VOLTS "PIXEL" MODULAR RGB LED with WS2011
#### What is it? This is a mini modular RGB panel (6767 mm) controlled with one WS2011 chip and 12 5050 RGB LED (about 3 watt) you can chain those panel to create your own lighting system. This is on…
Read More…#### What is it?
This is a mini modular RGB panel (6767 mm) controlled with one WS2011 chip and 12 5050 RGB LED (about 3 watt) you can chain those panel to create your own lighting system. This is one "PIXEL" that is you can modulate one colour per PIXEL (256256256 colours available), but next in your daisy chain can be driven with other colour.
#### Why did you make it?
This panel has been ordered for a large light hight power simulator cabin, the customer requirement was high about quality and lifetime under a very long lighting period, so we design this module on Aluminium PCB to increase natural cooling as LED lose their brightness, then life as they become too hot.
#### What makes it special?
Use 24V DC for 12 RGB LED per panel Aluminium PCB for natural high-efficiency thermal dissipation
APPLICATIONS EXAMPLES
WHAT IS INCLUDED
ORDERING
Please note that this item needs a 24V controller and 24-volt DC power supply to run, some are available in our shop or you can build your's own with ARDUINO board for example
price decrease with large quantities, please ask for shipping quotation depending on your qty and destination
Enter your email address if you'd like to be notified when WS2811 12 RGB LED MODULAR panel - 24volts can be shipped to you:
1-9 | $6.50 |
10-24 | $5.50 |
25-49 | $5.00 |
50-99 | $4.50 |
100-499 | $4.00 |
500-999 | $3.50 |
1000+ | $3.00 |
$105.00
$33.00
$41.00
