7 RGB LED WS2812 5Volts 294 * 8mm flexible RIBBON pack of 5 units
Sold By SmartElectronic
This is a flexible RGB LED ribbon with a WS2812 embedded driver inside each LED This means that you can control each LED independently from others with a suitable LED controller. This ribbon is reall…
Read More…This is a flexible RGB LED ribbon with a WS2812 embedded driver inside each LED This means that you can control each LED independently from others with a suitable LED controller.
This ribbon is really narrow with only 8 mm width and can almost fit everywhere
As this is flexible you can easily double tape in many places to illuminate whatever you want
A small SMD button at the end can drive some special design controller on line 4 (see picture)
With a little practice, you can also chain those modules to increase the length
Power is 5 volts only
We offer with the original mini just 4 pins OR JST 3 PIN SM connector USUALLY USED BY CONTROLLER(SEE PICTURE)
yOU CAN USE OUR CONTROLLER HERE :
or any controller for WS2811 running 5 volts
Enter your email address if you'd like to be notified when WS2812 RGB 5050 LED 294 * 8mm RIBBON pack of 5 can be shipped to you:
1-4 | $6.00 |
5-9 | $5.00 |
10-24 | $4.50 |
25+ | $4.00 |
$105.00
$33.00
$41.00
$6.50
$9.98
$9.00
