A 6HP eurorack module that does most essential utility tasks in one package!
Designed by Soft Synthetics in United Kingdom
What is CAV? CAV is very useful 6HP eurorack utility module. It's made of 2 units which can each: crossfade, attenuvert, attenuate, or be a voltage source. These units are chained together and have a…
Read More…CAV is very useful 6HP eurorack utility module. It's made of 2 units which can each: crossfade, attenuvert, attenuate, or be a voltage source. These units are chained together and have a 3rd output which sums them together. This setup allows a single module to perform most utility tasks in one package!
And more...
It uses big 45mm LED sliders for maximum fun and blinkenlights.
The module is 6HP and Front panel made of aluminium.
If this is all familiar to you then you should know I had a little rebrand from 49_chakras and made some much needed improvements to the original circuit.
The first batch of modules (V3.3) have a voltage source maximum range or +- 2.5V, (V3.4) and beyond includes a range of +-5V for more modulation control and may be modified yourself to change this range.
The ink on the black side of the front panel is not as clean as it could be. I've reflected that in the price until I produce some cleaner versions/ get some help from proper graphic designer! The Aluminium reverse side looks very cool but the white ink has very low contrast.
This run of modules comes entirely SMD pre-soldered. to finish the build you need 7 Thonkiconn Jacks, 2 LED 45mm sliders, a couple ferrite beads/lengths of wire, some headers, jumpers, and screws. Build Guide
More information, guides, and hacks available at: https://www.softsynthetics.com/CAV
I also offer assembly service. As I am just a person with a table and a cheap soldering iron I can only offer this product "as is" with no warranty. But I'm more than happy to offer support if something has gone wrong! I will not provide the 2x5 idc power cable until I have a proper reliable method of manufacturing these and won't mark up something you can do at home/buy off the from your local synth shop (if your luck enough to have one).
Enter your email address if you'd like to be notified when CAV - Crossfading, Attenuverting, Voltage Source can be shipped to you:
1 | $25.00 |
2+ | $23.00 |
