ESP32-based media center device with a HiFi DAC and a powerful D-class amp
Designed by Sonocotta in PolandThis seller is taking a break until April 27, 2025. Sign up below to get an email when they're back!
What is it Amped-ESP32 combines ubiquitous ESP32 with a PCM5100 HiFi DAC teamed up with a highly efficient TPA3110D2 D-class amplifier. It brings all the best from the HiFi-ESP32 model and adds an on…
Read More…Amped-ESP32 combines ubiquitous ESP32 with a PCM5100 HiFi DAC teamed up with a highly efficient TPA3110D2 D-class amplifier. It brings all the best from the HiFi-ESP32 model and adds an onboard amp to form a complete solution that can be paired with speakers directly. It uses an external power source to feed hungry amps and the host MCU using an onboard drop-down converter. It has similar power capabilities to the Louder-ESP32 model, but it is much simpler to use since it only needs a valid I2S signal to operate, so a simple book example code will do it.
I spent the last few years developing different solutions based on ESP devices. It all started with ESP8266, where CPU power is not really sufficient to do real-time decoding, so you're limited to a rather simple ding-dong business. Then ESP32 came, bringing two much more capable cores, so you have a powerhouse to handle communication and decoding at the same time. Perhaps most importantly it also came with SPIRAM, so you can do decent buffering (essential for streamed content). Now new ESP32 C-Series and S-Series chips are entering the market, and their potential is mostly unrealized as of today.
I created ESP32 Audio docks and subsequently development boards, to be able to quickly prototype for the whole range of ESP8266 and ESP32 chips, starting with the simplest finger-sized toys and going all the way up to full-sized speakers.
Recently I went a rabbit hole of Home Assistant integrations and discovered different ways ESP32 with a decent DAC can be integrated into complex Home setups.
Audio streaming requires proper buffering to work, even with ESP32 500K of RAM it is a challenging task. For that reason, most of the projects will require WROVER modules that have onboard PSRAM chips. All ESP32 Audio boards have an 8MB PSRAM chip onboard, connected via a high-speed interface. Any code using PSRAM with just work out-of-the box.
HiFi-ESP32 | Loud-ESP32 | Amped-ESP32 | Louder-ESP32 | |
Image (ESP32) | ||||
MCU | ESP32-WROVER-N8R8 onboard | ESP32-WROVER-N8R8 onboard | ESP32-WROVER-N8R8 onboard | ESP32-WROVER-N8R8 onboard |
Image (ESP32-S3) | coming soon | |||
MCU (S3) | ESP32-S3-WROOM-N8R8 onboard | ESP32-S3-WROOM-N8R8 onboard | ESP32-S3-WROOM-N8R8 onboard | ESP32-S3-WROOM-N8R8 onboard |
DAC | PCM5100A 32bit Stereo DAC -100 dB typical noise level | Dual I2S DAC (MAX98357) with built in D-Class amp | PCM5100A 32bit Stereo DAC working with TPA3110D2 D-Class amp | Stereo I2S DAC (TAS5805M) with built in D-Class amp |
Output (4Ω) | Non-amplified stereo output, 2.1V RMS | 2x 5W | 2x 22W (4Ω, 1% THD+N) at 16V 2x 32W (4Ω, 1% THD+N) at 20V 1x 40W (4Ω, 1% THD+N) at 20V (bridged) | 2x 22W (4Ω, 1% THD+N) at 16V 2x 32W (4Ω, 1% THD+N) at 20V 1x 40W (4Ω, 1% THD+N) at 20V (bridged) |
Output (8Ω) | Non-amplified stereo output | 2x 3W | 2x 25W (8Ω, 1% THD+N) at 22V | 2x 25W (8Ω, 1% THD+N) at 22V |
PSRAM | ESP32: 8MB PSRAM (4MB usable) over 40MHz SPIESP32S3: 8MB PSRAM over 80MHz QSPI | ESP32: 8MB PSRAM (4MB usable) over 40MHz SPIESP32S3: 8MB PSRAM over 80MHz QSPI | ESP32: 8MB PSRAM (4MB usable) over 40MHz SPIESP32S3: 8MB PSRAM over 80MHz QSPI | ESP32: 8MB PSRAM (4MB usable) over 40MHz SPIESP32S3: 8MB PSRAM over 80MHz QSPI |
Power | 5V over USB-C, 2x LP5907 3.3 V Ultra-Low-Noise LDO for analog section | 5V (up to 2.5A) from USB-C | Up to 26V from external PSU | Up to 26V from external PSU |
Connectivity | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) |
I2S CLK | I2S DATA | I2S WS | PSRAM RESERVED | |
ESP32 | 26 | 22 | 25 | 16, 17 |
ESP32-S3 | 14 | 16 | 15 | 35, 36, 37 |
SPI CLK | SPI MOSI | SPI MISO | SPI CS | SPI HOST/SPEED | ETH INT | ETH RST | |
ESP32 | 18 | 23 | 19 | 05 | 2/20MHz | 35 | 14 |
ESP32-S3 | 12 | 11 | 13 | 10 | SPI2/20MHz | 6 | 5 |
IR IN | RGB OUT | OLED SPI HOST/SPEED | OLED SPI CLK | OLED SPI MOSI | OLED SPI MISO | OLED SPI CS | OLED SPI DC | OLED RST | |
ESP32 | 39 | 12 | 2/20MHz | 18 | 23 | 19 | 15 | 4 | 32 |
ESP32-S3 | 7 | 9 | SPI2/20MHz | 12 | 11 | 13 | 39 | (37) | 38 |
and Upload
Follow the ESP8266Audio library guide. Default settings will work out of the box with ESP8266 and ESP32 boards. For ESP32C3 and ESP32S2 board please adjust the pinout according to the above section
ESPHome will give you ESPHome configs for Solo board running with ESP32-S2/S3, as well as Duo/HiFi-ESP and Amped ESP working with ESP32.
Few words of explanation.
media_player
Squeezelite-ESP32 is a multimedia software suite, that started as a renderer (or player) of LMS (Logitech Media Server). Now it is extended with - Spotify over-the-air player using SpotifyConnect (thanks to cspot) - AirPlay controller (iPhone, iTunes ...) and enjoy synchronization multiroom as well (although it's AirPlay 1 only) - Traditional Bluetooth device (iPhone, Android)
And LMS itself - Streams your local music and connects to all major online music providers (Spotify, Deezer, Tidal, Qobuz) using Logitech Media Server - a.k.a LMS with multi-room audio synchronization. - LMS can be extended by numerous plugins and can be controlled using a Web browser or dedicated applications (iPhone, Android). - It can also send audio to UPnP, Sonos, Chromecast, and AirPlay speakers/devices.
All ESP32-based boards are tested with Squeezelite-ESP32 software, which can be flashed using nothing but a web browser. You can use Squeezelite-ESP32 installer for that purpose.
Connect the device to the USB port and select it from the list | |
Exit recovery |
You can use it now
Please visit the hardware section for board schematics and PCB designs. Note that PCBs are shared as multi-layer PDFs.
ESP32 | ESP32-S3 |
coming soon |
Every board has a header that allows to solder in W5500 SPI Ethernet module that is very easy to find. The only downside is that with the module installed board will not fit the case, unless it is cut to accomodate extra height.
HiFi-ESP32(S3) | Loud-ESP32(S3) |
On the latest boards (starting from Amped-ESP32), I switched to barrel jack with thick middle pin with a 2.5mm pin, it’s a bit unusual but still common enough in the laptop world. It is far more comfortable in handling high currents, and importantly, much more sturdy and resistant to desoldering.
The power adapter specs depend on the speaker you're planning to use. DAC efficiency is close to 100%, so just take the power rating of your speaker (say 2x10w), and impedance (say 8 ohms), and you'd need at least 9 volts rated at 1.2 amps per channel, round up to 3 total amps.
It is not recommended to go beyond the voltage your speakers can handle, otherwise, the amp will blow your speakers in no time.
The Amped-ESP32(S3) is mechanically compatible with Raspberry Pi 4 cases, tested with transparent ones. Also, community members created a few 3-D printable designs that can be found here and here
Amped-ESP32 |
Enter your email address if you'd like to be notified when Amped ESP32 can be shipped to you:
1 | $24.00 |
2-4 | $23.00 |
5-9 | $22.00 |
10+ | $20.00 |
