Home Media Center powered by Raspberry Pi and PCM5100 DACs paired with TPA3110 D-class amp
What is it? The Amped Raspberry Pi Media Center is a compact and neatly designed hardware project that combines the power of the Raspberry Pi Zero board and the Hi-Fi audio capabilities of the TI’s P…
Read More…The Amped Raspberry Pi Media Center is a compact and neatly designed hardware project that combines the power of the Raspberry Pi Zero board and the Hi-Fi audio capabilities of the TI’s PCM5100 HiFi DAC combined with a highly efficient TPA3110D2 D-class amplifier. This versatile media center provides a customizable and fully open-source hardware platform for home entertainment.
With a minimalistic but functional design inspired by commercial audio gear, it offers a seamless user experience. It aimed to support Volumio, Mopidy, or any custom firmware you may come up with.
I did a few audio projects in the past, some using ESP32, some using larger Orange Pi and Raspberry Pi devices. Each has its pros and cons, and in each iteration, I'm trying to focus on the details that were working best for me while actually using them.
What is special about the Raspberry ecosystem is, of course, its community support. Being a not-so-strong software developer, I often have to rely on the work that other people did and baked into the base Raspbian image. Enabling the Ethernet and IR reader is as simple as adding 2 lines into config.txt
file. Adding DAC is a 5-minute job (with attached code). All the device tree definitions, kernel drivers, and dependency packages are already in place, believe it or not.
Amped Raspberry Pi Media Center brings all the best from the HiFi model and adds an onboard amp to form a complete solution that can be paired with speakers directly. It uses an external power source to feed hungry amps and host Pi using an onboard drop-down converter. It has similar power capabilities to the Amped Raspberry DAC, but it is much simpler to use since it only needs a valid I2S signal to operate, so it is a single line of configuration in the config.txt
file.
HiFi Raspberry Media Center and Hat | Amped Raspberry Media Center and Hat | Loud Raspberry Media Center and Hat | Amped Raspberry Media Center and Hat | |
Image (Media Center) | ||||
Image (Hat) | ||||
Image (Hat, 2X) | ||||
I2S CLK | I2S DATA | I2S WS | |
Raspberry Pi Zero | 18 | 21 | 19 |
Raspberry Pi 2,3 | 18 | 21 | 19 |
Raspberry Pi 5 | 18 | 21, 23, 25, 27 | 19 |
You need nothing more than an SD card with a Raspbian image and a USB-C power brick. You can use any distribution you like. The only change you need to make to enable hardware is to add 3 lines to the /boot/config.txt
dtoverlay=hifiberry-dac
Front | Back | PCB |
The “hammer-style” solution I came up with is a NOPD version of the Amped Raspberry that lets you use a barrel power jack to supply raw voltage directly. The catch? Standard 2mm pins can’t handle high currents, so I’ve gone with a 2.5mm pin instead — it’s a bit unusual, but still common enough in the laptop world.
With this setup, you can supply more than the 20V limit of PD, giving you a bit more power for the speakers. You probably won’t hear much difference (thanks to the way human hearing works), but it could help larger speakers that need a bit more to really “open up." Other than that, the NOPD version works just like the PD version — no software changes are needed.
The power adapter specs depend on the speaker you're planning to use. DAC efficiency is close to 100%, so just take the power rating of your speaker (say 2x10w) and impedance (say 8 ohms), and you'd need at least 9 volts rated at 1.2 amps per channel, round up to 3 total amps. Consider Pi itself drawing 5-10W of power when busy.
It is not recommended to go beyond the voltage your speakers can take, otherwise, the amp will blow your speakers in no time.
The absolute maximum voltage for the TPA3110 Amp is 30V, but it is not guaranteed to be thermally stable in this condition.
Enter your email address if you'd like to be notified when Amped Raspberry Pi Media Center can be shipped to you:
