Add audio capability to your ESP8266, ESP32, ESP32-S2 or ESP32-S3 module
Designed by Sonocotta in PolandThis product is no longer available for sale.
What is it ESP Audio Docks is a range of extension boards (i.e. docks) that allow you to develop Audio solutions based on ESP8266 and ESP32 chips. These were created to make Audio development entry a…
Read More…ESP Audio Docks is a range of extension boards (i.e. docks) that allow you to develop Audio solutions based on ESP8266 and ESP32 chips. These were created to make Audio development entry as easy and inexpensive as possible.
I'm working on a v2 design of the Docks. New boards are improving some of the aspects of the Docks, while also trying to push the price down.
All v2 designs are adding a few new features on top
I spent the last few years developing different solutions based on ESP devices. It all started with ESP8266, where CPU power is not really sufficient to do real-time decoding, so you're limited to rather simple ding-dong business. Then ESP32 came, bringing two much more capable cores, so you have powerhouse to handle communication and decoding at the same time. Perhaps most importantly it also came with 4MB of PSRAM, so you can do decent buffering (essential for streamed content).
Now new ESP32 C-Series and S-Series chips are entering the market, and their potential is mostly unrealized as of today.
I created those docks, to be able quick prototype for whole range of ESP8266 and ESP32 chips, starting with the simplest finger-sized toys and going all the way up to full-sized speakers.
ESP Audio Solo | ESP Audio Duo | Hifi ESP (superseded by HiFi-ESP32) | Louder ESP (superseded by HiFi-ESP32) | |
Image | ![]() |
Docks with | ESP8266, ESP32C3, ESP32S2 Mini modules | ESP32 Mini Module | ESP32 Mini Module | ESP32 Mini Module |
DAC | Single I2S DAC (MAX98357) with built in D-Class amp | Dual I2S DAC (MAX98357) with built in D-Class amp | PCM5100A 32bit Stereo DAC -100 dB typical noise level | Stereo I2S DAC (TAS5805M) with built in D-Class amp |
Output (4Ω) | 3W | 2x 3W | Non-amplified stereo output | 2x 15W at 12V Vin |
Output (8Ω) | 1.5W | 2x 1.5W | Non-amplified stereo output | 2x 23W at 22V Vin |
Adds | 8MB PSRAM (4MB usable) | 8MB PSRAM (4MB usable) | 8MB PSRAM (4MB usable) |
Audio streaming require proper buffering to work, even with ESP32 500K of RAM it is a challenging task. For that reason most of the projects will require WROVER modules that have onboard PSRAM chip.
All ESP32 Docks has 8MB PSRAM chip onboard, connected via high-speed SDIO interface. This effectively turns your regular WROOM module into WROVER module with no effort required. Any code using PSRAM with just work out-of-the box.
I2S CLK | I2S DATA | I2S WS | |
ESP8266 | 15 | 3 | 2 |
ESP32C3 | 5 | 20 | 6 |
ESP32S2 | 12 | 37 | 16 |
I2S CLK | I2S DATA | I2S WS | PSRAM CE | PSRAM CLK | |
ESP32 | 26 | 22 | 25 | 16 | 17 |
In the software section two firmware examples provided.
All samples are provided as Plarformio IDE projects. After installing it, open sample project. Select proper environment based on your dock. Run Build
and Upload
commands to install necessary tools and libraries, build and upload prject to the board. Communication and proper upload method selection will be handled by IDE automatically.
Follow the ESP8266Audio library guide. Default settings will work out of the box with ESP8266 and ESP32 boards. For ESP32C3 and ESP32S2 board please adjust pinout according to the above section
Few words of explanation.
media_player
Squeezelite-ESP32 is a multimedia software suite, that started as renderer (or player) of LMS (Logitech Media Server). Now it is extended with - Spotify over-the-air player using SpotifyConnect (thanks to cspot) - AirPlay controller (iPhone, iTunes ...) and enjoy synchronization multiroom as well (although it's AirPlay 1 only) - Traditional Bluetooth device (iPhone, Android)
And LMS itself - Streams your local music and connect to all major on-line music providers (Spotify, Deezer, Tidal, Qobuz) using Logitech Media Server - a.k.a LMS with multi-room audio synchronization. - LMS can be extended by numerous plugins and can be controlled using a Web browser or dedicated applications (iPhone, Android). - It can also send audio to UPnP, Sonos, ChromeCast and AirPlay speakers/devices.
All ESP32 based boards are tested with Squeezelite-ESP32 software, that can be flashed using nothing but web-browser. You can use Squeezelite-ESP32 installer for that purpose.
Connect the device to USB port and select it from the list | |
When redirected to captive portal let device scan wifi network and provide valid credentials | |
(Optional) You may change device names to something close to you heart | |
Exit recovery |
You can use it now
Please visit hardware section for board schematics and PCB designs. Note that PCB are shared as multi-layer PDFs.
Image | Legend |
Image | Legend |
Image | Legend |
Jason | May 25, 2024
