ESP32 based streaming upgrade for your legacy stereo system
What is it Esparagus HiFi MediaLink is a handy low-cost media device, that will upgrade your legacy audio system with cutting-edge internet streaming capabilities and enhance your audio experience. O…
Read More…Esparagus HiFi MediaLink is a handy low-cost media device, that will upgrade your legacy audio system with cutting-edge internet streaming capabilities and enhance your audio experience.
Our Crowd Supply campaign for backing the manufacturing of Esparagus series boards is currently underway. If you have any interest, please consider subscribing to receive updates on the campaign.
I did few audio projects in the past, some using ESP32, some using larger Orange Pi and Raspberry Pi devices. Each has its pros and cons, and with each iteration, I'm trying to focus on the details that were working best for me, while actually using them.
What I like about ESP32 is how lightweight it is. It barely draws power, so you may not care to turn it off at all. It boots in seconds and is ready for use in a snap. Still, it is capable and works at par with Linux SBC solutions for audio applications while costing a fraction of their price. Combined with a proper Hi-Fi DAC you would not tell a difference to commercial devices standing side by side and costing much more.
Over the last few years, I have seen a few amazing software products created to deliver audio on the ESP32, like squeezelite-esp32 or euphonium. Esparagus HiFi MediaLink is designed specifically to run these great pieces of software and bring a new life into aging audio equipment that most of us have at home, but do not use that much these days, since it is not working with Spotify and the family.
ESP Audio Duo | Loud Esparagus | Hifi ESP | HiFi Esparagus | Louder ESP32 | Louder Esparagus | |
Image | ![]() |
Docks with | ESP32 Mini Module | ESP32-WROVER-N8R8 onboard | ESP32 Mini Module | ESP32-WROVER-N8R8 onboard | ESP32-WROVER-N16R8 onboard | ESP32-WROVER-N16R8 onboard |
DAC | Dual I2S DAC (MAX98357) with built in D-Class amp | Dual I2S DAC (MAX98357) with built in D-Class amp | PCM5100A 32bit Stereo DAC | PCM5100A 32bit Stereo DAC -100 dB typical noise level | Stereo I2S DAC (TAS5805M) with built in D-Class amp | Stereo I2S DAC ( TAS5805M ) with built in D-Class amp |
Power | 5V from Mini-USB | 5V from USB-C | 5V from USB-C | 5V from USB-C | Up to 26V from external PSU | Up to 20V from USB-C PD |
Output, 4Ω | 2x 3W | 2x 3W | Non-amplified stereo output | Non-amplified stereo output | 2x 32W (4Ω, 1% THD+N) | 2x 32W (4Ω, 1% THD+N) |
Output, 8Ω | 2x 5W | 2x 5W | - | - | 2x 22W (8Ω, 1% THD+N) | 2x 22W (8Ω, 1% THD+N) |
PSRAM | 8MB PSRAM (4MB usable) | 8MB PSRAM (4MB usable) Onboard | 8MB PSRAM (4MB usable) | 8MB PSRAM (4MB usable) Onboard | 8MB PSRAM (4MB usable) | 8MB PSRAM (4MB usable) Onboard |
Peripheral | External WiFi Antenna, WS2812B RGB Led, SSD1306 128x64 OLED screen (optional) | External WiFi Antenna, WS2812B RGB Led, SSD1306 128x64 OLED screen (optional) | External WiFi Antenna WS2812B RGB Led SSD1306 128x64 OLED screen (optional), IR receiver, W5500 SPI LAN | |||
Connectivity | WiFi + BT4.2 + BLE | WiFi + BT4.2 + BLE | WiFi + BT4.2 + BLE | WiFi + BT4.2 + BLE | WiFi + BT4.2 + BLE | WiFi + BT4.2 + BLE Ethernet |
Size | 39 x 31 x 20mm | 80 x 50 x 20mm | 39 x 31 x 20mm | 80 x 50 x 20mm | 86 x 56 x 20mm | 100 x 80 x 38mm |
Software support | Arduino samples, ESPhome config | Arduino samples, squeezelite-esp32, snapcast, ESPhome config | Arduino samples, squeezelite-esp32, snapcast, ESPhome config | Arduino samples, squeezelite-esp32, snapcast, ESPhome config | Arduino samples, squeezelite-esp32, snapcast, ESPhome config | Arduino samples, squeezelite-esp32, snapcast, ESPhome config |
Audio streaming requires proper buffering to work, even with ESP32 500K of RAM it is a challenging task. Esparagus HiFi MediaLink is based on a WROVER module that has an onboard PSRAM chip.
I2S CLK | I2S DATA | I2S WS | PSRAM CE | PSRAM CLK | |
ESP32 | 26 | 22 | 25 | 16 | 17 |
SPI HOST | SPI CLK | SPI MOSI | SPI MISO | OLED DC | OLED CS | OLED RST | WS2812 RGB LED | |
ESP32 | 2 | 18 | 23 | 19 | 4 | 5 | 32 | 33 |
and Upload
Follow the ESP8266Audio library guide.
Few words of explanation.
media_player
Squeezelite-ESP32 is a multimedia software suite, that started as a renderer (or player) of LMS (Logitech Media Server). Now it is extended with
And LMS itself
All Esparagus boards are tested with Squeezelite-ESP32 software. It can be flashed using nothing but a web browser. You can use Squeezelite-ESP32 installer for that purpose.
Use Esparagus Squeezelite-ESP32 installer to flash the firmware. It has been preconfigured to work with Esparagus boards and will configure all hardware automatically.
Select correct device first | |
Connect the device to USB port and select it from the list | |
(Optional) You may enter the serial console to get more information, like device IP and boot logs | |
Exit recovery |
You can use it now
Esparagus HiFi MediaLink |
Please visit the hardware section for board schematics and PCB designs. Note that PCBs are shared as multi-layer PDFs as well as Gerber archives.
Enter your email address if you'd like to be notified when Esparagus HiFi MediaLink can be shipped to you:
Currently, Poczta Polska does not ship to Israel, and a few more countries due to a lack of airline operations. As soon as they will lift the restrictions, I'll restore shipments.
Bruno | Dec. 27, 2024
Adrian | April 28, 2024
Allard | March 19, 2024
Lonja | Feb. 22, 2024
