Raspberry Pi Hat powered by two PCM5100 DACs paired with TPA3110 D-class amp
Designed by Sonocotta in PolandThis seller is taking a break until April 27, 2025. Sign up below to get an email when they're back!
What is it? The Amped Raspberry Pi Hat is a PCM5100 HiFi DAC combined with a highly efficient TPA3110D2 D-class amplifier. It brings all the best from the HiFi Raspberry Pi Hat model and adds an onbo…
Read More…The Amped Raspberry Pi Hat is a PCM5100 HiFi DAC combined with a highly efficient TPA3110D2 D-class amplifier. It brings all the best from the HiFi Raspberry Pi Hat model and adds an onboard amplifier to form a complete solution that can be paired with speakers directly. It uses an external power source to feed hungry amps and host Pi using an onboard drop-down converter.
1X | 2X |
Amped Raspberry Pi Hat comes in two flavors: 1X hat is a stereo DAC and stereo Amp that will work with pretty much any Raspberry out there, while 2X Hat is a dual setup delivering 4 independent channels using Raspberry Pi 5 capability of multi-channel I2S.
I did a few audio projects in the past, some using ESP32, some using larger Orange Pi and Raspberry Pi devices. Each has its pros and cons, and with each iteration, I'm trying to focus on the details that were working best for me while actually using them.
What is special about the Raspberry ecosystem is, of course, its community support. Being a not-so-strong software developer, I often have to rely on the work that other people did and baked into the base Raspbian image. Attaching a DAC, Ethernet, and IR reader is as simple as adding 3 lines into config.txt
file. All the device tree definitions, kernel drivers, and dependency packages are already in place, believe it or not.
Amped Raspberry Pi uses the legendary PCM5100 series DAC with supreme audio quality. It feeds its output to the TPA3110 D-class amp with both great sound and unbelievable power efficiency. You can use it with either small or large speakers directly plugged into the Hat. The hat will require an external power source to drive your speakers properly, but it will also power Pi itself through a power-efficient drop-down regulator, allowing the whole setup to run using a single power source. It is absurdly simple to set up, as it uses no extra configuration compared to the PCM5100 DAC itself, so any Raspberry Linux distribution has everything you need.
Image (Media Center) | ||||
Image (Hat) | ||||
Image (Hat, 2X) | ||||
I2S CLK | I2S DATA | I2S WS | TPA3110 EN | |
Raspberry Pi Zero | 18 | 21 | 19 | [Rev A, B] 5,6 |
Raspberry Pi 2,3 | 18 | 21 | 19 | [Rev A, B] 5,6 |
Raspberry Pi 5 | 18 | 21, 23, 25, 27 | 19 | [Rev A, B] 5,6,7,8 |
You need nothing more than an SD card with a Raspbian image and a USB-C power brick. You can use any distribution you like. The only change you need to make to enable hardware is to add 3 lines to the /boot/config.txt
dtoverlay=hifiberry-dac
Originally, amps could be shut down using GPIO pins, but in the latter version of the board, I removed that functionality. The reason is that TPA3116 doesn't have a dedicated MUTE pin, and I was using the SHDN pin for that purpose. Changing the voltage on that pin created a pop sound, no matter how slowly I changed the voltage. I'm planning to switch to a more modern TPA32XX series going forward to solve this issue.
If you have early board and want to control the amp using GPIO, you may use software integration to pull GPIO5/6 HIGH or LOW to switch the amp ON and OFF.
The project repository provides a few examples with build instructions, including Volumio setup instructions, among others.
1X | 2X |
Raspberry Pi 5 is the first one that allows the user to drive multiple I2S data lines using the same interface. What it means in practice is that while all older Pis have just 3 I2S lines (CLK, WS, DATA), Pi5 supports up to 4 Data lines (CLK, WS, D0, D1, D2, D3), capable of driving 4 independent audio interfaces.
2X Raspberry Pi hats support alternative data lines. You need to short some solder bridge to use it, though. It allows configuring Hats to use different pins and stack them together to create 4 individual stereo interfaces (8 channels in total) using the same device.
By default, the 2X hat uses pins 21,23 for data, with the possibility to switch to pins 25 and 27 with solder bridges and stack 2 boards together.
HiFi Hat (rev C) | HiFi Hat (rev D) | HiFi-Amped Hat | Loud Hat |
The configuration value that allows this is quite simply
dtoverlay=hifiberry-dac8x
At this point, all Hats with 1X marking a single DAC version that can be used with every Pi, including Pi 5. The 2X version uses two data lines of the Pi5 and will work out of the box with it. It can be changed to use a second set of data lines, so 2 boards stacked together will utilize 4 DACs or 8 channels of audio. You can short data lines together and use 2X Hat with Pi2/3/4, having 2 parallel DAC channels.
Enter your email address if you'd like to be notified when Amped Raspberry Pi Hat can be shipped to you:
