Home Media Center powered by Orange Pi and PCM5100 DAC
What is it? The Orange Pi Home Media Center is a compact and neatly designed hardware project that combines the power of the Orange Pi One board and the Hi-Fi audio capabilities of the TI’s PCM5100 3…
Read More…The Orange Pi Home Media Center is a compact and neatly designed hardware project that combines the power of the Orange Pi One board and the Hi-Fi audio capabilities of the TI’s PCM5100 32-bit DAC. This versatile media center provides a customizable and fully open-source hardware platform for home entertainment.
With a minimalistic but functional design inspired by commercial audio gear, it offers a seamless user experience. It aimed to support Volumio, Mopidy, or any custom firmware you may come up with.
I did a few audio projects in the past, some using ESP32, some using popular Raspberry Pi devices. Each has its pros and cons, and with each iteration, I'm trying to focus on the details that were working best for me, while using them myself on a daily basis.
What is special about the Orange Pi is the amount of hardware power that you get for your buck. Surely, the ecosystem is not as rich as Raspberry Pi, and the community is not so vast. But Armbian is still a Debian-based system and most of the things you'd want to run, just work!
Orange Pi HiFi is a first-in-line product that uses the legendary PCM5100 series DAC with supreme audio quality. It exposes line-level output that you can plug into a stereo amplifier. Spend as much as you need on the external amp to deliver the sound you like (personally I prefer late 80's audio gear).
HiFi Orange Pi Media Center (this device) | Loud Orange Pi Media Center | Louder Orange Pi Media Center (work in progress) | |
Image | WIP | ||
DAC | PCM5100A 32bit Stereo DAC | Dual I2S DAC MAX98357 with built in D-Class amp | Stereo I2S DAC TAS5805M with built in D-Class amp |
Output | 2.1 VRMS Line level output / -100 dB typical noise level | 2x 3W (8Ω); 2x 5W (4Ω) | 2x 22W (8Ω, 1% THD+N); 2x 32W (4Ω, 1% THD+N) |
IR reader | yes | yes | yes |
RGB LED | yes | yes | yes |
External relay driver | yes | no | yes |
Ethernet | built-in | built-in | built-in |
Powers from | 5V USB-C power adapter / Triple LP5907 3.3 V Ultra-Low-Noise LDO | 25W+ USB-C PD power adapter | 65W USB-C PD power adapter (25W/45W with limited power) |
Mechanical dimensions (WxHxD) | 88mm x 38mm x 100mm | 88mm x 38mm x 100mm | 88mm x 38mm x 100mm |
I2S CLK | I2S DATA | I2S WS | |
Orange Pi One | PA19 | PA20 | PA18 |
WS2812 RGB LED | RELAY EN | IR INPUT | |
Orange Pi One | PA7 | PA2 | PA9 |
SPI CLK | SPI MOSI | SPI MISO | TFT CS | TFT DC | TFT RES | TFT LED | |
Orange Pi One | PC2 | PC0 | PC1 | PC3 | PA0 | PA1 | PA3 |
A | B | BTN | |
Orange Pi One | PC7 | PC4 | PA6 |
Being a Debian-based Orange Pi Media Center is a vast space for experimentation. First things first, for any OS you need to configure DAC. The below instruction is based on Armbian experience, that supports the current kernel (thus already having DAC kernel modules).
The linked Github repository provides detailed instructions on how to configure and test DAC in a few bash commands.
Ansible is an automation suite that allows you to configure systems remotely using redistributable configurations called playbooks.
A few playbooks were created to allow 2-clicks deployment for Hi-Fi Orange Pi. The same can be done manually by pulling necessary packages from the vast Debian software store.
Front | Back | PCB |
Enter your email address if you'd like to be notified when HiFi Orange Pi Media Center can be shipped to you:
