What is it? The Raspberry Pi HiFi Hat is a cost-effective version of the Raspberry Pi Home Media Center. It combines the power of the Raspberry Pi SBC and the Hi-Fi audio capabilities of the TI’s PCM…
Read More…The Raspberry Pi HiFi Hat is a cost-effective version of the Raspberry Pi Home Media Center. It combines the power of the Raspberry Pi SBC and the Hi-Fi audio capabilities of the TI’s PCM5100 32-bit DAC.
1X | 2X |
Raspberry Pi HiFi Hat is the lightweight implementation of the same PCM5100A DAC and power circuitry in a Hat shape. It has two flavors: 1X is a traditional DAC that works with any Raspberry Pi out there, while 2X is specifically designed for Raspberry Pi 5 and implements two stereo-DACs, which Raspberry Pi 5 users can use independently. Using two of them, you can have up to 4 stereo outputs, totaling 8 channels of audio.
I did a few audio projects in the past, some using ESP32, some using larger Orange Pi and Raspberry Pi devices. Each has its pros and cons, and with each iteration, I'm trying to focus on the details that were working best for me while actually using them.
What is special about the Raspberry ecosystem is, of course, its community support. Being a not-so-strong software developer, I often have to rely on the work that other people did and baked into the base Raspbian image. Attaching a DAC, Ethernet, and IR reader is as simple as adding 3 lines into config.txt
file. All the device tree definitions, kernel drivers, and dependency packages are already in place, believe it or not.
Raspberry Pi HiFi is a first-in-line product that uses the legendary PCM5100 series DAC with supreme audio quality. It exposes a 2.1V RMS level output that you can plug into a stereo amplifier. Spend as much as you need on the external amp to deliver the sound you like (personally, I prefer late '80s audio gear).
Image (Media Center) | ||||
Image (Hat) | ||||
Image (Hat, 2X) | ||||
I2S CLK | I2S DATA | I2S WS | IR INPUT | |
Raspberry Pi Zero | 18 | 21 | 19 | 17 |
Raspberry Pi 2,3,4 | 18 | 21 | 19 | 17 |
Raspberry Pi 5 | 18 | 21, 23, 25, 27 | 19 | 17 |
You need nothing more than an SD card with a Raspbian image and a USB-C power brick. You can use any distribution you like. The only change you need to make to enable hardware is to add 3 lines to the /boot/config.txt
dtoverlay=gpio-ir,gpio_pin=17
dtoverlay=hifiberry-dac
The project repository provides a few examples with build instructions, including Volumio setup instructions, among others.
Image |
Please follow this guide to configure an IR reader
Raspberry Pi 5 is the first one that allows the user to drive multiple I2S data lines using the same interface. What it means in practice is that while all older Pis have just 3 I2S lines (CLK, WS, DATA), Pi5 supports up to 4 Data lines (CLK, WS, D0, D1, D2, D3), capable of driving 4 independent audio interfaces.
2X Raspberry Pi hats support alternative data lines. You need to short some solder bridge to use it, though. It allows configuring Hats to use different pins and stack them together to create 4 individual stereo interfaces (8 channels in total) using the same device.
By default, the 2X hat uses pins 21,23 for data, with the possibility to switch to pins 25 and 27 with solder bridges and stack 2 boards together.
HiFi Hat (rev C) | HiFi Hat (rev D) |
The configuration value that allows this is quite simply
dtoverlay=hifiberry-dac8x
Enter your email address if you'd like to be notified when HiFi Raspberry Pi Hat can be shipped to you:
Documentation: (4.00)
Shipping: (4.00)
Joel | Feb. 8, 2025
$74.00
