Home Media Center powered by Raspberry Pi and PCM5100 DAC
What is it? The Raspberry Pi Home Media Center is a compact and neatly designed hardware project that combines the power of the Raspberry Pi Zero board and the Hi-Fi audio capabilities of the TI’s PC…
Read More…The Raspberry Pi Home Media Center is a compact and neatly designed hardware project that combines the power of the Raspberry Pi Zero board and the Hi-Fi audio capabilities of the TI’s PCM5100 32-bit DAC. This versatile media center provides a customizable and fully open-source hardware platform for home entertainment.
With a minimalistic but functional design inspired by commercial audio gear, it offers a seamless user experience. It aimed to support Volumio, Mopidy, or any custom firmware you may come up with.
I did a few audio projects in the past, some using ESP32, some using larger Orange Pi and Raspberry Pi devices. Each has its pros and cons, and in each iteration, I'm trying to focus on the details that were working best for me while actually using them.
What is special about the Raspberry ecosystem is, of course, its community support. Being a not-so-strong software developer, I often have to rely on the work that other people did and baked into the base Raspbian image. Attaching a DAC, Ethernet, and IR reader is as simple as adding 3 lines into config.txt
file. All the device tree definitions, kernel drivers, and dependency packages are already in place, believe it or not.
Raspberry Pi HiFi is a first-in-line product that uses the legendary PCM5100 series DAC with supreme audio quality. It exposes line-level output that you can plug into a stereo amplifier. Spend as much as you need on the external amp to deliver the sound you like (personally, I prefer late '80s audio gear).
Image (Media Center) | ||||
Image (Hat) | ||||
Image (Hat, 2X) | ||||
I2S CLK | I2S DATA | I2S WS | |
Raspberry Pi Zero | 18 | 21 | 19 |
SPI CLK | SPI MOSI | SPI MISO | LAN RES | LAN CS | LAN INT | WS2812 RGB LED | RELAY EN | IR INPUT | |
Raspberry Pi Zero | 11 | 10 | 9 | 24 | 8 | 25 | 12 | 7 | 23 |
You need nothing more than an SD card with a Raspbian image and a USB-C power brick. You can use any distribution you like. The only change you need to make to enable hardware is to add 3 lines to the /boot/config.txt
dtoverlay=gpio-ir,gpio_pin=23
dtoverlay=w5500
dtoverlay=hifiberry-dac
Front | Back | PCB |
Enter your email address if you'd like to be notified when HiFi Raspberry Pi Media Center can be shipped to you:
Cyrus | Aug. 11, 2024
