Availability A new batch is coming from the factory around mid-November. Until then boards are available to purchase from Crowd Supply What is it Loud Esparagus is a compact media center device aimed…
Read More…A new batch is coming from the factory around mid-November. Until then boards are available to purchase from Crowd Supply
Loud Esparagus is a compact media center device aimed to be paired with small-to-medium-sized speakers in a small room. It uses a dual MAX98357 Hi-Fi DAC that will output 3W per speaker. Admittedly not much, but well enough for a kid's room or workplace. Due to the D-class amp, it barely uses power and can be paired with a standard USB wall charger.
Our Crowd Supply campaign for backing the manufacturing of Esparagus series boards is currently underway. If you have any interest, please consider subscribing to receive updates on the campaign.
I did few audio projects in the past, some using ESP32, some using larger Orange Pi and Raspberry Pi devices. Each has its pros and cons, and with each iteration, I'm trying to focus on the details that were working best for me, while actually using them.
What I like about ESP32 is how lightweight it is. It barely draws power, so you may not care to turn it off at all. It boots in seconds and is ready for use in a snap. Still, it is capable and works at par with Linux SBC solutions for audio applications, while costing a fraction of their price. Combined with a proper Hi-Fi DAC you would not tell a difference to commercial devices standing side by side and costing much more.
Over the last few years, I have seen a few amazing software products created to deliver audio on the ESP32, like squeezelite-esp32 or euphonium. Esparagus media center devices are designed specifically to run these great pieces of software and bring a new life into aging audio equipment that most of us have at home but do not use that much these days, since it is not working with Spotify and the family.
HiFi Esparagus | Loud Esparagus | Louder Esparagus | Amped Esparagus | |
Image | ||||
MCU | ESP32-WROVER-N8R8 | ESP32-WROVER-N8R8 | ESP32-WROVER-N16R8 | ESP32-WROVER-N16R8 |
DAC | PCM5100A 32bit Stereo DAC -100 dB typical noise level | Dual I2S DAC (MAX98357) with built in D-Class amp | Stereo I2S DAC ( TAS5805M ) with built in D-Class amp | PCM5100A 32bit Stereo DAC working with TPA3110D2 D-Class amp |
Power | 5V over USB-C, 2x LP5907 3.3 V Ultra-Low-Noise LDO for analog section | 5V from USB-C | Up to 20V from USB-C PD or up to 26V from generic power adapter | Up to 20V from USB-C PD or up to 26V from generic power adapter |
Output, 4Ω | Non-amplified stereo output | 2x 3W | 2x 32W (4Ω, 1% THD+N) | 2x 22W (4Ω, 1% THD+N) at 16V 1x 40W (4Ω, 1% THD+N) at 20V |
Output, 8Ω | - | 2x 5W | 2x 22W (8Ω, 1% THD+N) | 2x 25W (8Ω, 1% THD+N) at 22V |
PSRAM | 8MB PSRAM (4MB usable) | 8MB PSRAM (4MB usable) | 8MB PSRAM (4MB usable) | 8MB PSRAM (4MB usable) |
Peripheral | WS2812B RGB Led SSD1306 128x64 OLED screen (optional) | WS2812B RGB Led SSD1306 128x64 OLED screen (optional) | WS2812B RGB Led SSD1306 128x64 OLED screen (optional) | 8xWS2812B RGB Led SSD1306 128x64 OLED screen (optional) Rotary encoder with push button |
Connectivity | WiFi BT4.2 BLE | WiFi BT4.2 BLE | WiFi BT4.2 BLE W5500 Ethernet | WiFi BT4.2 BLE W5500 Ethernet |
Size | 80 x 50 x 20mm | 80 x 50 x 20mm | 100 x 80 x 38mm | 100 x 80 x 38mm |
Software support | Arduino samples, squeezelite-esp32, snapcast, ESPhome config | Arduino samples, squeezelite-esp32, snapcast, ESPhome config | Arduino samples, squeezelite-esp32, snapcast, ESPhome config | Arduino samples, squeezelite-esp32, snapcast, ESPhome config |
Audio streaming requires proper buffering to work, even with ESP32 500K of RAM it is a challenging task. Loud Esparagus is based on a WROVER module that has an onboard PSRAM chip.
I2S CLK | I2S DATA | I2S WS | PSRAM CE | PSRAM CLK | |
ESP32 | 26 | 22 | 25 | 16 | 17 |
SPI HOST | SPI CLK | SPI MOSI | SPI MISO | OLED DC | OLED CS | OLED RST | WS2812 RGB LED | RELAY EN | |
ESP32 | 2 | 18 | 23 | 19 | 4 | 5 | 32 | 33 | 21 |
and Upload
commands to install necessary tools and libraries, and build and upload project to the board. Communication and proper upload method selection will be handled by IDE automatically.
Follow the ESP8266Audio library guide.
Few words of explanation.
media_player
Squeezelite-ESP32 is a multimedia software suite, that started as a renderer (or player) of LMS (Logitech Media Server). Now it is extended with
And LMS itself
Use Esparagus Squeezelite-ESP32 installer to flash the firmware. It has been preconfigured to work with Esparagus boards and will configure all hardware automatically.
Select correct device first | |
Connect the device to USB port and select it from the list | |
(Optional) You may enter the serial console to get more information, like device IP and boot logs | |
Exit recovery |
You can use it now
Loud Esparagus |
Please visit the hardware section for board schematics and PCB designs. Note that PCBs are shared as multi-layer PDFs as well as Gerber archives.
Loud Esparagus |
Loud Esparagus |
Enter your email address if you'd like to be notified when Loud Esparagus Media Center can be shipped to you:
1 | $45.00 |
2+ | $40.00 |
Shipping: (4.00)
Stephen | Jan. 17, 2025
