Raspberry Pi Audio Hat powered by quadruple MAX98357A DAC
What is it? The Loud Raspberry Pi Hat is a cost-effective version of the Loud Raspberry Pi Home Media Center. It combines the power of the Raspberry Pi SBC and the Hi-Fi audio capabilities of the Ana…
Read More…The Loud Raspberry Pi Hat is a cost-effective version of the Loud Raspberry Pi Home Media Center. It combines the power of the Raspberry Pi SBC and the Hi-Fi audio capabilities of the Analog Devices MAX98357A DAC.
1X | 2X |
Loud Raspberry Pi Hat has the same DAC and audio circuitry in a cost-efficient Hat form. The 1X version can be used with any Raspberry Pi, while Raspberry Pi 5 users can use two pairs of speakers independently on the 2X version. Hat will pull the juice from the Pi's 5V line, or power the Pi itself using screw connectors, so you can make sure enough power is delivered to both boards.
I did a few audio projects in the past, some using ESP32, some using larger Orange Pi and Raspberry Pi devices. Each has its pros and cons, and with each iteration, I'm trying to focus on the details that were working best for me while actually using them.
What is special about the Raspberry eco-system is, of course, its community support. Being a not-so-strong software developer, I often have to rely on the work that other people did and baked into the base Raspbian image. Attaching a DAC, Ethernet, and IR reader is as simple as adding 3 lines into config.txt
file. All the device tree definitions, kernel drivers, and dependency packages are already in place, believe it or not.
Loud Raspberry Pi uses a quad MAX98357 HiFi DAC with a built-in highly efficient D-class amp to deliver 3 to 5W of music power directly to your speakers. It is not too loud, but it is very simple to use and fun to play with. It powers from a standard USB-C power source, like a phone charger or a standard 5V wall adapter delivering a few amps.
Image (Media Center) | ||||
Image (Hat) | ||||
Image (Hat, 2X) | ||||
I2S CLK | I2S DATA | I2S WS | MAX98357A EN | |
Raspberry Pi Zero | 18 | 21 | 19 | 5 |
Raspberry Pi 2,3,4 | 18 | 21 | 19 | 5 |
Raspberry Pi 5 | 18 | 21, 23, 25, 27 | 19 | 5, 6 |
You need nothing more than an SD card with a Raspbian image and a USB-C power brick. You can use any distribution you like. The only change you need to make to enable hardware is to add 3 lines to the /boot/config.txt
dtoverlay=max98357a,sdmode-pin=5
The project repository provides a few examples with build instructions, including Volumio setup instructions, among others.
1X | 2X |
Below are the power requirements for different Pi models
Model | Power requirement |
Raspberry Pi Zero W | 260 mA (1.3 W) |
Raspberry Pi Zero 2 W | 500 mA (2.5 W) |
Raspberry Pi 3 Model B | 1.34 A (6.7 W) |
Raspberry Pi 3 Model B+ | 1.21 A (6.05 W) |
Raspberry Pi 3 Model A+ | 0.75 A (3.75 W) |
Raspberry Pi 4 Model B (1GB, 2GB, 4GB, and 8GB RAM variants) | 3.0 A (15 W) |
Raspberry Pi 5 | Approximately 3.5 A |
Consider each 5W of expected audio output to be another 1A of the current budget and buy a reasonable power source capable of delivering the sum of Pi and audio requirement with a reasonable margin of 15%+
In the extreme scenario, using all 4 channels with 4 Ohms load with Pi5, you'd need (3A [Pi] + 4A [audio]) * 1.2 = 8.4A
or 42W, round up to 50W.
Raspberry Pi 5 is the first one that allows the user to drive multiple I2S data lines using the same interface. What it means in practice is that while all older Pis have just 3 I2S lines (CLK, WS, DATA), Pi5 supports up to 4 Data lines (CLK, WS, D0, D1, D2, D3), capable of driving 4 independent audio interfaces.
2X Raspberry Pi hats support alternative data lines. You need to short some solder bridge to use it, though. It allows configuring Hats to use different pins and stack them together to create 4 individual stereo interfaces (8 channels in total) using the same device.
By default, the 2X hat uses pins 21,23 for data, with the possibility to switch to pins 25 and 27 with solder bridges and stack 2 boards together.
Loud Hat |
The device tree that can utilize all channels and DACs on and off properly is a work in progress. But a quick and dirty way to enable all channels is to use hifiberry-dac8x
device tree. It lacks enable pins, and thus they need to be permanently switched on in the software.
The configuration value that allows this is quite simply
dtoverlay=hifiberry-dac8x
Enter your email address if you'd like to be notified when Loud Raspberry Pi Hat can be shipped to you:
$74.00
