ESP32 audio development board with TAS5805M I2S DAC, driving 2x 23W load (8Ω, 1% THD+N)
Availability New restocking batches are regularly ordered from the factory, as I plan to keep all the versions in stock at least until the new revision of the board is released. For availability, you…
Read More…New restocking batches are regularly ordered from the factory, as I plan to keep all the versions in stock at least until the new revision of the board is released. For availability, you may also visit the official reseller store.
Louder-ESP32 combines ubiquitous ESP32 with an I2S DAC with built-in D-class amplifier capable of driving full-size speakers. This combination provides your compact ESP32 module with the necessary memory and RAM capabilities to develop Hi-Fi products.
I spent the last few years developing different solutions based on ESP devices. It all started with ESP8266, where CPU power is not really sufficient to do real-time decoding, so you're limited to a rather simple ding-dong business. Then ESP32 came, bringing two much more capable cores, so you have a powerhouse to handle communication and decoding at the same time. Perhaps most importantly it also came with SPIRAM, so you can do decent buffering (essential for streamed content). Now new ESP32 C-Series and S-Series chips are entering the market, and their potential is mostly unrealized as of today.
I created ESP32 Audio docks and subsequently development boards, to be able to quickly prototype for the whole range of ESP8266 and ESP32 chips, starting with the simplest finger-sized toys and going all the way up to full-sized speakers.
Recently I went a rabbit hole of Home Assistant integrations and discovered different ways ESP32 with a decent DAC can be integrated into complex Home setups.
Audio streaming requires proper buffering to work, even with ESP32 500K of RAM it is a challenging task. For that reason, most of the projects will require WROVER modules that have onboard PSRAM chips. All ESP32 Audio boards have an 8MB PSRAM chip onboard, connected via a high-speed interface. Any code using PSRAM with just work out-of-the box.
HiFi-ESP32 | Loud-ESP32 | Amped-ESP32 | Louder-ESP32 | |
Image (ESP32) | ||||
MCU | ESP32-WROVER-N8R8 onboard | ESP32-WROVER-N8R8 onboard | ESP32-WROVER-N8R8 onboard | ESP32-WROVER-N8R8 onboard |
Image (ESP32-S3) | coming soon | |||
MCU (S3) | ESP32-S3-WROOM-N8R8 onboard | ESP32-S3-WROOM-N8R8 onboard | ESP32-S3-WROOM-N8R8 onboard | ESP32-S3-WROOM-N8R8 onboard |
DAC | PCM5100A 32bit Stereo DAC -100 dB typical noise level | Dual I2S DAC (MAX98357) with built in D-Class amp | PCM5100A 32bit Stereo DAC working with TPA3110D2 D-Class amp | Stereo I2S DAC (TAS5805M) with built in D-Class amp |
Output (4Ω) | Non-amplified stereo output, 2.1V RMS | 2x 5W | 2x 22W (4Ω, 1% THD+N) at 16V 2x 32W (4Ω, 1% THD+N) at 20V 1x 40W (4Ω, 1% THD+N) at 20V (bridged) | 2x 22W (4Ω, 1% THD+N) at 16V 2x 32W (4Ω, 1% THD+N) at 20V 1x 40W (4Ω, 1% THD+N) at 20V (bridged) |
Output (8Ω) | Non-amplified stereo output | 2x 3W | 2x 25W (8Ω, 1% THD+N) at 22V | 2x 25W (8Ω, 1% THD+N) at 22V |
PSRAM | ESP32: 8MB PSRAM (4MB usable) over 40MHz SPIESP32S3: 8MB PSRAM over 80MHz QSPI | ESP32: 8MB PSRAM (4MB usable) over 40MHz SPIESP32S3: 8MB PSRAM over 80MHz QSPI | ESP32: 8MB PSRAM (4MB usable) over 40MHz SPIESP32S3: 8MB PSRAM over 80MHz QSPI | ESP32: 8MB PSRAM (4MB usable) over 40MHz SPIESP32S3: 8MB PSRAM over 80MHz QSPI |
Power | 5V over USB-C, 2x LP5907 3.3 V Ultra-Low-Noise LDO for analog section | 5V (up to 2.5A) from USB-C | Up to 26V from external PSU | Up to 26V from external PSU |
Connectivity | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) |
I2S CLK | I2S DATA | I2S WS | PSRAM RESERVED | TAS5805 SDA | TAS5805 SCL | TAS5805 PWDN | TAS5805 FAULT | |
ESP32 | 26 | 22 | 25 | 16, 1 | 21 | 27 | 33 | 34 |
ESP32-S3 | 14 | 16 | 15 | 35, 36, 37 | 8 | 9 | 17 | 18 |
SPI CLK | SPI MOSI | SPI MISO | SPI CS | SPI HOST/SPEED | ETH INT | ETH RST | |
ESP32 | 18 | 23 | 19 | 05 | 2/20MHz | 35 | 14 |
ESP32-S3 | 12 | 11 | 13 | 10 | SPI2/20MHz | 6 | 5 |
IR IN | RGB OUT | OLED SPI HOST/SPEED | OLED SPI CLK | OLED SPI MOSI | OLED SPI MISO | OLED SPI CS | OLED SPI DC | OLED RST | |
ESP32 | 39 | 12 | 2/20MHz | 18 | 23 | 19 | 15 | 4 | 32 |
ESP32-S3 | 7 | 9 | SPI2/20MHz | 12 | 11 | 13 | 39 | (37) | 38 |
and Upload
Follow the ESP8266Audio library guide. Default settings will work out of the box with ESP8266 and ESP32 boards. For ESP32C3 and ESP32S2 board please adjust the pinout according to the above section
Few words of explanation.
media_player
Squeezelite-ESP32 is a multimedia software suite, that started as a renderer (or player) of LMS (Logitech Media Server). Now it is extended with - Spotify over-the-air player using SpotifyConnect (thanks to cspot) - AirPlay controller (iPhone, iTunes ...) and enjoy synchronization multiroom as well (although it's AirPlay 1 only) - Traditional Bluetooth device (iPhone, Android)
And LMS itself - Streams your local music and connects to all major online music providers (Spotify, Deezer, Tidal, Qobuz) using Logitech Media Server - a.k.a LMS with multi-room audio synchronization. - LMS can be extended by numerous plugins and can be controlled using a Web browser or dedicated applications (iPhone, Android). - It can also send audio to UPnP, Sonos, Chromecast, and AirPlay speakers/devices.
All ESP32-based boards are tested with Squeezelite-ESP32 software, which can be flashed using nothing but a web browser. You can use Squeezelite-ESP32 installer for that purpose.
Please find detailed instructions on the linked GitHub
The default configuration of the squeezelite-esp32 runs automatic discovery of the available LMS server nearby. In fact it depends on it so much that in case the LMS service is not found on the network, it will reboot automatically (every few minutes).
In many cases, if you use squeezelite for Airplay and Spotify only and don't have LMS servier, you need to disable discovery altogether. Currently, disabling Squeezelite in the GUI does not work correctly; it places too many spaces between the commands in the autoexec command. Following autoexec1
NVS setting can be used to disable it:
squeezelite -o i2s -s -disable -b 500:2000 -C 30 -d all=sdebug
ESP32-S3 boards have two ways of firmware update: (1) similarly to classing ESP32, they can be flashed over built-in UART, or (2) uniquely for S3, over built-in USB host controller. Since it is firmware-controlled, and may be disabled if not used (or, more commonly, not available with factory default empty firmware). When come unflashed ESP32-S3 device comes into a boot loop, with a USB-CDC device appearing and disappearing every second, and requires a special flashing initialisation sequence to get flashed:
esp_tool
Please visit the hardware section for board schematics and PCB designs. Note that PCBs are shared as multi-layer PDFs.
Image |
Every board has a header that allows to solder in W5500 SPI Ethernet module that is very easy to find. The only downside is that with the module installed board will not fit the case, unless it is cut to accomodate extra height.
HiFi-ESP32(S3) | Louder-ESP32(S3) |
image coming soon... |
TAS5805M DAC Allows 2 modes of operation - BTL (stereo) and PBTL (parallel, or mono). In Mono amp will use a completely different modulation scheme and basically will fully synchronize output drivers. Jumpers on the board allow both output drivers to connect to the same speaker. The most important step is to inform the Amp to change modulation in the first place via I2C comman. In the case of sqeezelite DAC controls set value is the following:
dac_controlset: {"init":[{"reg":3,"val":2},{"reg":3,"val":3},{"reg":2,"val":4}],"poweron":[{"reg":3,"val":3}],"poweroff":[{"reg":3,"val":0}]}
compared to default: dac_controlset: {"init":[{"reg":3,"val":2},{"reg":3,"val":3}],"poweron":[{"reg":3,"val":3}],"poweroff":[{"reg":3,"val":0}]}
One can test audio with a single speaker connected between L and R terminals (plus on one side and minus on the other). Optionally, jumpers on the board will effectively connect the second driver in parallel doubling the current capability.
Important point, this will send only one channel to the output, that’s just how the DAC works. True mono as (L+R)/2 is possible via more in-depth configuration (very poorly documented), but I haven’t managed to configure that on the stand. I’m still working on that. (Along with a few more really cool DSP features that this DAC has, like EQ, subwoofer mode and tone compensation settings)
BTL | PBTL | |
Descriotion | Bridge Tied Load, Stereo | Parallel Bridge Tied Load, Mono |
Rated Power | 2×23W (8-Ω, 21 V, THD+N=1%) | 45W (4-Ω, 21 V, THD+N=1%) |
Schematics | ||
Speaker Connection |
Starting from Rev E, an additional header is exposed to allow datasheet-specced connectivity
Image | Legend |
Stereo Mode - leave open | |
Mono (PBTL) Mode, close horisontally |
The TAS5805M DAC has a very powerful DSP, that allows doing lots of data processing on the silicon, that otherwise would take a considerable part of your CPU time. As of the moment of writing it is mostly an undiscovered part of the DAC, since unfortunately, TI is not making it very easy for developers. (A minute of complaint) To be more specific, you need to be (A) a proven hardware manufacturer to get access to the configuration software, namely PurePath. (B) you need to apply for a personal license and go through an approval process, and after a few weeks of waiting you get access to one DAC configuration you asked for. (C) You find out that it will work with TI's own evaluation board that will set you back $250 if you'd be able to find one. Otherwise, all you have is a list of I2C commands that you need to transfer to the device on your own cost. No wonder no one knows how to use it.
But moanings aside, what do you get after:
At this moment it is very experimental. In the perfect world, you should be able to adjust all of those settings to make your speaker-enclosure setup work the best it can, and even apply your room factors into the equation. But with above disclaimer I can only deliver limited set of configurations corresponding to the most common use cases:
All of the above are available right now for experimentation. I'm keen to hear your feedback while I moving forward with porting this to other software options
Barrel jack used is spaced at 6mm hole/2mm pin, which is typically 5.5/2.5mm jack on the male side.
The screw terminal is connected parallel to the barrel jack, you can use either interchangeably.
The power adapter specs depend on the speaker you're planning to use. DAC efficiency is close to 100%, so just take the power rating of your speaker (say 2x10w), and impedance (say 8 ohms) and you'd need at least 9 volts rated at 1.2 amps per channel, round up to 3 total amps.
It is not recommended to go beyond the voltage your speakers can take, otherwise amp will blow your speakers in no time.
Important: do not connect Vin and USB-C at the same time, or you will cook your USB-C port! I didn't want to lose voltage on the voltage-select circuit, so these two sources are connected. While developing and debugging, a USB-C power source will be sufficient to run DAC with a power limit of ~5W per channel.
HiFi-ESP32(S3), Loud-ESP32(S3) and Louder-ESP32(S3) are mechanically compatible with Raspberry Pi 3/4 cases, tested with transparent ones. Also, community members created a few 3-D printable designs that can be found here and here
Louder-ESP32 |
Enter your email address if you'd like to be notified when Louder ESP32 can be shipped to you:
1 | $24.00 |
2-4 | $23.00 |
5-9 | $22.00 |
10+ | $20.00 |
Product: (4.83)
Documentation: (4.25)
Shipping: (4.50)
Communication: (4.83)
Albert | Aug. 21, 2025
Julian | May 4, 2025
Bruno | March 15, 2025
Kilian | Feb. 14, 2025
Arnaud | Dec. 27, 2024
Oyvind | Nov. 2, 2024
Miguel | Oct. 30, 2024
Fabian | Sept. 11, 2024
Erik | Aug. 13, 2024
Adrian | March 13, 2024
Dustin | Jan. 31, 2024
Maickel | Dec. 30, 2023
$74.00
