Raspberry Pi Audio Hat powered by TI's TAS5805M DAC
Designed by Sonocotta in PolandThis seller is taking a break until April 27, 2025. Sign up below to get an email when they're back!
Availability The new batch is coming from the factory and should be in stock by early January. It introduces an updated and improved board layout and lays the foundation for the upcoming dual DAC ver…
Read More…The new batch is coming from the factory and should be in stock by early January. It introduces an updated and improved board layout and lays the foundation for the upcoming dual DAC version of the board. I'm working towards delivering a DSP Linux driver for the board (in 2.0, 1.1, and 0.1 modes), adding dual DAC support for the 2.1 speaker config later.
The Louder Raspberry Pi Hat is a cost-effective version of the Louder Raspberry Pi Home Media Center. It combines the power of the Raspberry Pi SBC and the Hi-Fi audio capabilities of the TI’s TAS5805M DAC with a highly efficient D-Class output stage.
1X | 2X |
Louder Raspberry Pi Hat drops the USB-PD in favor of an external power supply up to 28V (opposed to 20V over PD) and has a step-down converter onboard to deliver 5V to the Pi, so you need only a single power source for everything. Otherwise, it delivers audio through the same highly capable DAC, capable of driving large speakers or tearing apart small ones.
A recent addition to the family is a 2X Louder Raspberry Pi Hat that utilizes two TAS5805M DACs connected in series to deliver flexible speaker configuration with a dedicated subwoofer driver.
I did a few audio projects in the past, some using ESP32, some using larger Orange Pi and Raspberry Pi devices. Each has its pros and cons, and with each iteration, I'm trying to focus on the details that were working best for me while actually using them.
What is special about the Raspberry eco-system is, of course, its community support. Being a not-so-strong software developer, I often have to rely on the work that other people did and baked into the base Raspbian image. Enabling an IR reader is as simple as adding a line to the config.txt
file. Adding DAC is a 5-minute job (with attached code). All the device tree definitions, kernel drivers, and dependency packages are already in place.
Louder Raspberry Pi is a top-of-the-range model that uses a modern, highly capable TAS5805M DAC and is aimed to be paired with medium-to-large speaker systems. With up to 30W per channel stereo output, it packs a punch and can easily enliven living quarters or dorm rooms. It is highly efficient, but much more demanding for power when cranked; therefore, it uses an external power adapter with up to 28V voltage reading (starting from as low as 7V).
Image (Media Center) | ||||
Image (Hat) | ||||
Image (Hat, 2X) | ||||
I2S CLK | I2S DATA | I2S WS | IR INPUT | |
Raspberry Pi Zero | 18 | 21 | 19 | 17 |
Raspberry Pi 2,3,4 | 18 | 21 | 19 | 17 |
Raspberry Pi 5 | 18 | 21 | 19 | 17 |
I2C CLK | I2C DATA | DAC PWDN | DAC FAULT | |
Raspberry Pi Zero | 3 | 2 | 4 | 26 |
Raspberry Pi 2,3,4 | 3 | 2 | 4 | 26 |
Raspberry Pi 5 | 3 | 2 | 4 | 26 |
You can use any distribution you like. To enable the IR reader, you need to add 1 line to the /boot/config.txt
dtoverlay=gpio-ir,gpio_pin=17
TAS5805M DAC is not supported by default Raspbian distribution, therefore, some work needs to be done to enable it. Linked repo contains code and instructions on how to configure it. It will take you 5 minutes and one reboot.
The project repository provides a few examples with build instructions, including Volumio setup instructions, among others.
1X | 2X |
Please follow this guide to configure an IR reader
TAS5805M DAC (and his big brother TAS5825M) has quite a sophisticated DSP inside, which is mostly undiscovered by the community at the moment. Documentation of it is scarce. The only reasonable way to use it is to obtain a TI PurePath license and Hardware Development kit ($250 if you find it). This should allow the following skills
Below are the power requirements for different Pi models
Model | Power requirement |
Raspberry Pi Zero W | 260 mA (1.3 W) |
Raspberry Pi Zero 2 W | 500 mA (2.5 W) |
Raspberry Pi 3 Model B | 1.34 A (6.7 W) |
Raspberry Pi 3 Model B+ | 1.21 A (6.05 W) |
Raspberry Pi 3 Model A+ | 0.75 A (3.75 W) |
Raspberry Pi 4 Model B (1GB, 2GB, 4GB, and 8GB RAM variants) | 3.0 A (15 W) |
Raspberry Pi 5 | Approximately 3.5 A |
Consider expected audio output to be a part of the power budget and buy a reasonable power source capable of delivering the sum of Pi and audio requirements with a reasonable margin of 15%+
In the extreme scenario, using 2 channels with 4 Ohms load with Pi5, you'd need (15W [Pi] + 60W [audio]) * 1.2 = 90W
, round up to 100W.
Enter your email address if you'd like to be notified when Louder Raspberry Pi Hat can be shipped to you:
