It will act like a physical mouse and draw perfect circles while you're away.
What is it Mouse Whisperer is a small development kit that is based on Microchip ATtiny85 MCU. It will act like a physical mouse and draw perfect circles while you're away. Why There are many reason…
Read More…Mouse Whisperer is a small development kit that is based on Microchip ATtiny85 MCU. It will act like a physical mouse and draw perfect circles while you're away.
There are many reasons why not, but also a few reasons why. Big Corpo tend to sell your convenience for security, don’t taking into account if you’re working in the office or from home.
Mouse Whisperer is there to bring some of that convenience back.
Mouse Whisperer is based on the Micronucleos bootloader, which allows USB communication for both flashing and user code communication.
Provided code sample initializes board as USB mouse device and draws perfect circles until switched off. It will indicate status with built-in RGB led. You can switch it ON and OFF by simply touching the edge of the board.
Mouse Whisperer comes preloaded with software. Simply insert it into USB socket, no drivers needed. Touch the edge of the board to switch it off, touch again to sswitch it back on.
If you wish to update software to your taste see information below.
Samples code in this repo provided as Platformio project, please follow the official Platformio installation guide first.
When a project is built using Platformio: Build
task and ready to be flashed, run Platformio: Upload
task. You insert your board into USB after that and the flashing process will start automatically. When done, code starts execution immediately.
Please follow Digispark tutorial
Enter your email address if you'd like to be notified when Mouse Whisperer can be shipped to you:
Robert | June 8, 2023
Chris | April 22, 2023
Aaron | Feb. 20, 2023
Scott | Feb. 6, 2023
Vincent | Jan. 9, 2023
$235.00
$69.95
