This breadboard compatible power supply module, plugs directly into your breadboard power rails and provides jumper selectable 5Volts, 3.3 volts or a variable output from 1.5 volts to 1.5 volts less …
Read More…This breadboard compatible power supply module, plugs directly into your breadboard power rails and provides jumper selectable 5Volts, 3.3 volts or a variable output from 1.5 volts to 1.5 volts less than the input voltage up to 24 volts input. The output voltage is also available on a 2 pin screw terminal on the right side of the board. Variable voltage adjusted by on board potentiometer. Output current to 1.5 amps.
A very convenient on board power solution, that provides common and adjustable dc volts for electronic experiments
Olathe, KS, United States of America
1 Review | 32 Orders
$34.95
$29.80
$26.00
$22.50
