Delta Electronics ASB0312MA-DF00 30mm 12V DC Axial Cooling Fan with Tachometer
Sold By STKN 3D PrintingFlea Market Item:
Ensure your equipment stays cool and operates efficiently with the Delta Electronics ASB0312MA-DF00, a high-performance 30mm axial fan designed for precision cooling in compact spaces. Renowned for i…
Read More…Ensure your equipment stays cool and operates efficiently with the Delta Electronics ASB0312MA-DF00, a high-performance 30mm axial fan designed for precision cooling in compact spaces. Renowned for its reliability and efficiency, this fan is the perfect solution for maintaining optimal temperatures in electronic devices, small machinery, and custom builds.
Key Features: Compact Design: 30mm x 30mm x 10mm dimensions make it ideal for tight spaces. Efficient Cooling: Delivers airflow of 3.72 CFM (0.105 m³/min) for superior cooling performance. High-Speed Operation: Runs at 9,000 RPM for rapid heat dissipation. Low Noise: Operates at a quiet 23.0 dB(A), ensuring minimal disruption. Durable Construction: Designed with a long-lasting sleeve bearing, providing an estimated lifespan of 20,000 hours at 40°C. Powerful Static Pressure: Produces 0.168 inch H₂O (4.27 mm H₂O) to meet demanding cooling requirements. Integrated Tachometer: Equipped with a speed sensor for real-time monitoring and operational precision. Energy Efficient: Consumes only 0.72 W, making it cost-effective and eco-friendly. Wide Operating Range: Reliable performance in temperatures ranging from -10°C to +70°C. Applications: Cooling for electronic components such as CPUs, GPUs, and power supplies. Embedded systems and small-form-factor PCs. Networking devices and custom-built electronics. Replacement fan for existing Delta ASB0312MA-DF00 applications. Specifications: Model: Delta Electronics ASB0312MA-DF00 Voltage: 12V DC Airflow: 3.72 CFM Noise Level: 23.0 dB(A) Speed: 9,000 RPM Power Consumption: 0.72 W Bearing Type: Sleeve Bearing Dimensions: 30mm x 30mm x 10mm Connector Type: 3-pin (included separately for your customization preferences) see pictures for detail
Applications: 3D Printing
3D Printer Cooling Hotend Fan Extruder Cooling Single Board Computers
Raspberry Pi Cooling Arduino Projects BeagleBone Black Electronics & DIY
DIY Electronics PCB Cooling Compact Cooling Fan Computer Components
GPU Cooling CPU Cooler Small Form Factor PC (SFF PC) Embedded Systems
IoT Devices Robotics Cooling Microcontroller Projects Networking Equipment
Router Cooling Switch Cooling Modem Cooling Audio/Visual Equipment
Media Player Cooling Amplifier Cooling Projector Cooling Gaming Consoles
Retro Console Cooling Compact Gaming Builds Replacement Parts
Replacement Cooling Fan Delta Electronics Fan Replacement Industrial Applications
Machine Cooling Compact Motors Automotive
Automotive Electronics Dashboard Cooling General Use
Small Cooling Fan Miniature Fan Axial Cooling Fan Why Choose Delta Electronics? Delta Electronics is a leader in the cooling technology industry, known for their innovative and reliable products that deliver top-notch performance across a variety of applications.
Shipping & Returns: Shipping: Fast same day shipping, with tracking provided. Returns: 30-day return policy for unused items in original condition. Don’t miss the chance to enhance your system’s cooling efficiency with this reliable and high-performing Delta ASB0312MA-DF00 axial fan! Buy now and keep your components running cool and quiet.
Enter your email address if you'd like to be notified when Delta Electronics ASB0312MA-DF00 30x30x10mm Fan can be shipped to you:
1-3 | $2.99 |
4+ | $1.99 |
Flea Market Item:
$16.95
$19.95
$16.95
$870.00
$638.99
