ATtiny Device Carrier PCB
Designed by Taste The Code in North MacedoniaNo shipping info available.
ATtiny Device PCB Prototyping carrier board that can turn the ATttiny85 into a slave I2C device What is it? Custom-designed PCB that is meant as a carrier board for the ATtiny85 chip. With it, the At…
Read More…Custom-designed PCB that is meant as a carrier board for the ATtiny85 chip. With it, the Attiny85 can be easily turned into a slave I2C device.
The board directly exposes the I2C lines to a pin header and provides a proto-board for the rest of your device.
Ever since I started tinkering with electronics, I was always amazed by the Attiny85 as it is so small and requires no extra components. So far, I have used it in many projects, but on a recent one, I had the idea to make a dedicated board that I can then use on more complex projects to offload some tasks to the Attiny85.
The ATTiny Device board is the simplest way of creating an Attiny85 I2C slave device. The included proto board allows for soldering of any extra required sensors or components and it also includes mounting holes so it can be secured inside enclosures.
You can check out this video to see me build an I2C controlled relay timer with this board and also check out my introduction post for it on my website. To get the code used with the example timer relay project, check out the GitHub repo here.
Enter your email address if you'd like to be notified when ATtiny Device PCB can be shipped to you:
1-4 | $2.59 |
5+ | $1.99 |
$13.80
