Breadboard jumper PCB that you can use to bridge over breadboard contacts and extend the number of pins connected in each row
Designed by Taste The Code in North Macedonia
What is it? The breadboard jumper PCB is used to electrically bridge over to another breadboard when you run out of pins on the current one. Not only that but the breadboard jumper can also be used …
Read More…The breadboard jumper PCB is used to electrically bridge over to another breadboard when you run out of pins on the current one.
Not only that but the breadboard jumper can also be used to bridge over the gap in the middle of the breadboard so you can have more connection points for your circuit.
I use mini breadboards for almost all of my projects and very often I find myself in situations to not have enough pins to connect everything that I need, so I often use multiple breadboards and a mess of wires to connect them.
With the breadboard jumper, I can instantly connect two mini breadboards together with a secure connection so all of the pins of one are instantly connected with the pins of the other breadboard.
The board has minimal dimensions so it does not interfere with microcontrollers attached to the breadboard like the NodeMCU or the Arduino Nano.
The headers holes are double-sided so once soldered, they provide excellent support for the headers and they will not separate from the board with repetitive use and removal from the breadboards.
Since the electrical connection is only made on one side, a special combination can be achieved by cutting some of the traces and soldering additional components like resistors and LEDs instead.
*The breadboard jumper is sold as a PCB only. You need to provide your own headers.
Enter your email address if you'd like to be notified when Mini Breadboard Jumper PCB can be shipped to you:
| Quantity | Price |
| 1-4 | $1.49 |
| 5-9 | $1.39 |
| 10-19 | $1.28 |
| 20+ | $1.19 |
$59.95
