Breakout board for 10 pin 0.05" header pin connector
Designed by TechDev LLC in United States of America
Easily wire a 10 pin 0.05" header to breadboards and test fixtures. This small board takes very little space while providing a solid connection to the header pins. The breakout connections are 0.1" s…
Read More…Easily wire a 10 pin 0.05" header to breadboards and test fixtures. This small board takes very little space while providing a solid connection to the header pins. The breakout connections are 0.1" spacing on a 0.1" grid. Wires or header pins can be inserted in the holes.
Enter your email address if you'd like to be notified when Mini-Breakout Board can be shipped to you:
$1.00
$1.00
