RF test board with 50 ohm traces.
Designed by TechDev LLC in United States of America
The 50 ohm RF Test board is built on 0.062 FR4 dielectric. It has edge mount SMA connector launches for SMA connectors that are available separately. Has a through connection for transmission measure…
Read More…The 50 ohm RF Test board is built on 0.062 FR4 dielectric. It has edge mount SMA connector launches for SMA connectors that are available separately. Has a through connection for transmission measurements and ground terminations on both ports for measuring reflection.
This board can be used as a calibrated test fixture for measuring component characteristics at high frequencies.
Enter your email address if you'd like to be notified when RF Test Board can be shipped to you:
1-3 | $3.00 |
4+ | $2.50 |
