This board converts the RGB and composite signals into a connector for the Sega Genesis HDMI converter.
Designed by Timex/Sinclair Nostalgia in United States of AmericaNo shipping info available.
If you own a Timex/Sinclair 2068, you know the video quality, even through the monitor jack, is poor. Back in the 1980s, RGB monitors were reasonably easy to come by and building your own adapter to …
Read More…If you own a Timex/Sinclair 2068, you know the video quality, even through the monitor jack, is poor. Back in the 1980s, RGB monitors were reasonably easy to come by and building your own adapter to connect your 2068 to the monitor was not very difficult.
Now, it's nearly impossible to find an old-school RGB monitor that works. And newer LCD monitors highlight every flaw in the 2068 video signal.
Well, use this converter with a Sega Genesis HDMI converter (available elsewhere for about $30) and you will experience the highest quality signal your 2068 can put out. It, simply, a thing of beauty. You will never go back to NTSC and all its flaws.
Take a look at the two screen captures. You should recognize the raw, straight-from-the-2068 video. The clean one? That's this circuit and the Sega converter.
Enter your email address if you'd like to be notified when 2068 RGB video to HDMI Timex/Sinclair can be shipped to you:
$34.99
$159.00
