an PC Engine / Turbografx16 1mb flashcard HuCARD
Designed by Marv17 in FranceThis seller is taking a break. Sign up below to get an email when they're back!
An HUCARD 1mb flashcard , for PC Engine or Turbografx-16 , without saving feature pcb have an ENIG finition they use soip-44 5v flashchip , they have two 3d printed parts , at bot for make the pcb re…
Read More…An HUCARD 1mb flashcard , for PC Engine or Turbografx-16 , without saving feature pcb have an ENIG finition
they use soip-44 5v flashchip , they have two 3d printed parts , at bot for make the pcb readable by the cartridge slot ( thickness from 1.6mm to around 2.4mm ) , and one at top for better look and protect the chip , you have the place for stick an label if you want.
the black pcb have a Pc Engine pinout the purple one an Turbografx-16 pinout ( reversed d0-d7 ) , you can flash them with my advanced adaptator for Sanni Card Reader : adaptator
or with directely on windows with my GUI dumper : dumper GUI
if you want use an Turbografx-16 pinout flashcard on an PCE , or an Pc Engine pinout flashcard on an Turbografx-16 , its possible by patching your rom , search for ''huconv.exe'' on search engine.
if you want lower the cost , you can order them without 3d printed parts , and print them yourself : it have a bot part , and a top cover one the bot one is necessary , cant work without ( for make the pcb from 1.6mm to around 2.4mm , the thickness of a hucard ) the top one is optionnal , for better look and the possibility to paste a sticker.
the parts are glued using double-sided tape
Enter your email address if you'd like to be notified when HuCard Flashcard 1mb , PC ENGINE / TURBOGRAFX-16 can be shipped to you:
Product in stock are shipped usually the day after the payment J+2 max ANY after sale service on shipment . if an Item is lost during transport , he will not be refunded
$15.99
$99.99
