ATTINY10 Based LED controller. For adding FX to your scale models
Designed by tiny-FX in Belgium
What is it? The tiny-FX mini is a ATTINY10 based LED controller for adding FX to your scale models, diecast cars, etc.. It is easy to use with the included JST XH connectors. Just connect the LED's w…
Read More…The tiny-FX mini is a ATTINY10 based LED controller for adding FX to your scale models, diecast cars, etc.. It is easy to use with the included JST XH connectors. Just connect the LED's with the JST cable (resistors are already mounted on the board) supply power. And off you go!
You have choice of pre programmed effects, or you can write your own program for the ATTINY10 - Running light (3 LED) - Left -> right (2 LED) - Strobe (3 LED)
Or ATTINY10 not soldered, this so that you can program one yourself.
Voltage range: 5 - 24V Max Output current 500mA per channel
I wanted to make life easy for the avg modeler that just want's to focus on making his models shine. Now they can do just that and add some LED FX as well.
The size 20x10x5 mm! But not only that it is one of the easiest to use modules in on the market.
Enter your email address if you'd like to be notified when tiny-FX mini can be shipped to you:
1-4 | $27.00 |
5+ | $25.00 |
