Kit to build a small, USB-C powerd bench power supply out of DPS3005 module
Designed by tokarski.dev in PolandThis seller is taking a break. Sign up below to get an email when they're back!
!! This is not a complete kit, you need to get a DC-DC module separately, see below for details !! What is it? It's a kit to build a compact bench power supply out of a cheap Chinese dc-dc converter …
Read More…!! This is not a complete kit, you need to get a DC-DC module separately, see below for details !!
It's a kit to build a compact bench power supply out of a cheap Chinese dc-dc converter module.
As a result, you get a device that is compact enough to live in a drawer and can be powered by a USB-C charger you probably already own. No need for dedicated shelf space or diving behind the desk to plug in the power cord. Works amazingly well for an occasional tinkerer with limited space.
You get all the parts necessary to build the power supply apart from the DC-DC module and USB-C charger.
Included in the kit are:
3D printed enclosure or files for 3D printing
Custom USB-C interface board
2x banana plug connectors
2x crocodile cables
6x M3 screws
4x silicone cables (cut to the right length and crimped)
4x stick-on rubber feet
You will need as those are not included in the kit:
a USB-PD compatible USB-C charger
DPS3005 DC-DC module (or similar)
You will also need a USB-C to USB-C cable, a Phillips screwdriver and a hex wrench :)
Most USB-C chargers are not well protected in case of a short circuit. There is no way to limit the power draw (constant current mode) or set a voltage easily.
Enter your email address if you'd like to be notified when USB-C Bench Power Supply kit can be shipped to you:
$136.50
