Eurorack passive multiple
Designed by TOMA Systems in Italy
Description When you're building up a patch it may happen that you'll need to duplicate a certain signal and feed it to multiple modules. You can use stackable cables or a multiple module like this o…
Read More…When you're building up a patch it may happen that you'll need to duplicate a certain signal and feed it to multiple modules. You can use stackable cables or a multiple module like this one.
The module is divided in two separate sections, each section consists of one input and three output jack sockets. However, if no cable is plugged on the input of the second section, the same signal coming from the first one is also propagated on all other outputs.
This is also a good chance to move your first steps in DIY modular and to learn how to use the soldering iron!
Selection | What you'll get |
PCB Only | PCB |
DIY Kit | PCB, All electronic components |
Fully Assembled | Ready to use module |
Enter your email address if you'd like to be notified when TS-213 Passive Multiple can be shipped to you:
$89.00
$55.34
