Stereo audio 3.5mm input/output switcher
Designed by Tom Archer in United Kingdom
What is it? This is a stereo audio switcher which allows: switching one 3.5mm input between two 3.5mm outputs, or switching one 3.5mm output between two 3.5mm inputs See the images for usage diagra…
Read More…This is a stereo audio switcher which allows:
See the images for usage diagrams.
Sometimes I don't want to turn my desktop PC on just to be able to listen to music. With this audio switcher I can connect both my desktop PC and my mobile phone to the same speakers and simply switch between the two of them as required!
It also works in reverse, connect one audio source to two different outputs e.g. headphones and speakers and easily switch between the two of them!
Some audio switchers use a common ground which can introduce an audible hum, others combine the left and right channels for mono audio. Using a 3PDT toggle switch means that the left, right and ground signals are all isolated and independently switched.
The PCB has also been designed so that the toggle-switch points in the direction of the selected audio source/destination for care free switching!
Size is approximately 4cm x 4cm x 4cm (1.5inch x 1.5inch x 1.5inch).
Choose from partially assembled or fully assembled:
Partially assembled option: This contains:
Fully assembled option: As above, but fully assembled and ready to go.
Note: Due to the size of the switch, the increased cost for this option is due to postage.
Enter your email address if you'd like to be notified when Stereo Audio Input/Output Switcher can be shipped to you:
Harpenden, Hertfordshire, United Kingdom
Ships from United Kingdom.
8 Reviews | 152 Orders
$78.00
$7.50
$140.00
