ESP32-C3 Dev Board with Energy Harvesting Circuit (BQ25504) for charging with a small solar cell
Designed by Lifex in Switzerland
What is it? This is an ESP32-C3 board I created for building a sensor cube. To make it (more or less) energy independent a energy harvesting circuit with the BQ25504 chip is added (inspired by this p…
Read More…This is an ESP32-C3 board I created for building a sensor cube. To make it (more or less) energy independent a energy harvesting circuit with the BQ25504 chip is added (inspired by this project. The board can be powered with a 3.7V LiPo battery which is charged by a small solar cell.
The board has a USB-C connector for powering and programming the ESP32-C3. It has 9 GPIO Pins, UART/Tx-Rx-Pins, Ground, 3.3V & 5V Pin. On board is also a WS2812B RGB Led.
I like the ESP32-C3 and wanted to create my own PCB board. I also wanted to learn the basics of KiCAD and PCB design. I will use this board for my other project: the sensor cube.
All components are placed on top of the board, so the bottom is empty/flat. As far as I have seen it's the only ESP32 board with an energy harvesting circuit on it.
It's small (25 mm x 25 mm) and square :)
Enter your email address if you'd like to be notified when ESP32-Tux Dev Board can be shipped to you:
Martin | Aug. 3, 2024
$15.74
$14.99
$22.40
