ESP32-C3 Microcontroller Dev Board
Designed by Lifex in Switzerland
What is it? This is a mini Dev Board Version I did for using it in the classroom for simple physical computing. The board has a USB-C connector for powering and programming the ESP32-C3. It has 9 GPI…
Read More…This is a mini Dev Board Version I did for using it in the classroom for simple physical computing.
The board has a USB-C connector for powering and programming the ESP32-C3. It has 9 GPIO Pins, UART/Tx-Rx-Pins, Ground, 3.3V & 5V Pin. On board is also a WS2812B RGB Led.
I like the ESP32-C3 and wanted to create my own PCB board. I also wanted to learn the basics of KiCAD and PCB design. I will use this board for my other project: the sensor cube.
It's small (20 mm x 20 mm) and light weight :)
Enter your email address if you'd like to be notified when ESP32-Tux Mini Dev Board can be shipped to you:
$3.99
$4.25
$23.00
