Industrial approved, powerfull, compact buck converter for high current systems
Designed by Yann Leidwanger in France
This powerfull compact modules is a buck power supply based on dedicated IC Due to specificities of some systems (available power supply and required poswer supply), I designed this compact and power…
Read More…This powerfull compact modules is a buck power supply based on dedicated IC
Due to specificities of some systems (available power supply and required poswer supply), I designed this compact and powerfull DC/DC module :
Vin = 12V...24V - Vout = 5V / 5A
ENABLE pin (tie pin to GND to disable, default enabled with on-board pull-up resistor)
PG pin (Power Good = 0V : outside voltage output window)
EMC improved routing and decoupling
power-on green LED
-compact size = 28mm x 36mm
Try it !
Enter your email address if you'd like to be notified when Buck converter : 12V...24V - 5V/5A can be shipped to you:
$4.50
$4.50
$44.00
$19.90
$29.90
$16.90
$13.10
