Wifi Enabled Co2 and temperature Monitor
Designed by Vishal's IoT in IndiaThis seller is taking a break. Sign up below to get an email when they're back!
This monitor the air around your personal space and can identify the high level of Co2 concentration It is really important for our health that we do not breath High level Co2 and considering modern …
Read More…This monitor the air around your personal space and can identify the high level of Co2 concentration
It is really important for our health that we do not breath High level Co2 and considering modern world where we have small air conditioned spaces and it is very easy that we are breathing unhealthy air everyday. Using this monitor you can easily see the current Co2 level and also see the graph of the Co2 readings
This is IoT enabled device which has WiFi built in, all the data can be monitored in the any WiFi enabled devices.
It also uses high quality infrared sensor which is very accurate.
Enter your email address if you'd like to be notified when Connected CO2 and Temperature sensor can be shipped to you:
$300.00
$109.00
