A 14HP stripboard dedicated to the Eurorack module format – a convenient way to prototype modules
Designed by Vlrm.Prjct in Germany
Wait what? A good alternative to standard stripboards: it’s easier to add potentiometers and jack connectors, easier to implement the power supply interface. And it’s already cut to Eurorack Frontpan…
Read More…A good alternative to standard stripboards: it’s easier to add potentiometers and jack connectors, easier to implement the power supply interface. And it’s already cut to Eurorack Frontpanel dimensions.
Power supply interface: 16 pins connector with silkscreened signal marks, filtering capacitors and bead filters or protection diodes.
You can use up to 6 potentiometers (9mm) or 6 Thonkiconn Jack connectors, or mix them. Includes a USB B Footprint.
The PCB is made in industry quality standard 1.6 mm thick, FR4 material. Plated through holes and green solder mask for easy soldering session.
This is PCB only, no components provided.
Enter your email address if you'd like to be notified when 14HP Eurorack module stripboard can be shipped to you:
$3.50
