Modular MIDI Controller goes Rack. Connect up to 8 modules on a main module.
Designed by Vlrm.Prjct in GermanyNo shipping info available.
What is it and what makes it special? The VLRM PRJCT CTRL is a universal arduino based MIDI controller for all kinds of MIDI controllable software. Based on my other Controller Project @ https://www.…
Read More…The VLRM PRJCT CTRL is a universal arduino based MIDI controller for all kinds of MIDI controllable software. Based on my other Controller Project @ https://www.tindie.com/products/17186/
All Modules fits in a 3U Eurorack. The Main-Module can be extend by up to 8 Control Modules. You can use it USB- or Bus-Powered. If want to use the Bus Power you need use the native MIDI-OUT Jack. This 3.5 Jack is wired as MIDI Type B according MIDI Standard, but there is a jumper option to switch to Type-A.
The VLRM PRJCT CTRL P8 Module has high quality pots with knobs designed in a 2 x 4 matrix. Various kinds of midi commands like control change, pitchbend, effects are possible. Of course you can assign the module pots to any commands by learning incoming midi commands like the software does.
The pots work with standard resolution of 7 bits to have full compatibility to any software instruments, effects and DAW’s.
All modules are assembled and delivered on order. The delivery time can be up to 10 days!
Enter your email address if you'd like to be notified when Modular Rack MIDI Controller can be shipped to you:
Shipping: (4.00)
Henjo | Aug. 23, 2020
$92.42
$109.99
$37.00
