1/4 wave vertical antenna parts
Designed by W5IPA-Jason in United States of America
Laser cut aluminum radial plate,SO-239 mount and vertical wire plate to DIY a 1/4 wave vertical antenna using your 10 Meter SpiderBeam Pole.Requires drilling and metal bending to mount the SO-239 mou…
Read More…Laser cut aluminum radial plate,SO-239 mount and vertical wire plate to DIY a 1/4 wave vertical antenna using your 10 Meter SpiderBeam Pole.Requires drilling and metal bending to mount the SO-239 mount to the Radial Plate. (All parts are 5052 .040 aluminum) NOTE:This is not a kit, you supply nylon spacers, hardware and SO-239.
Enter your email address if you'd like to be notified when Aluminum plates to DIY a 1/4 wave vertical can be shipped to you:
$23.00
$9.95
