Low profile add on board to attach an ESP32 development board to the Flipper Zero
Designed by Water_Ghoul in United States of America
What is it? A low profile add on board for the Flipper Zero to attach an ESP32 development board. It connects the power and serial lines of the Flipper to the ESP32 for use with Marauder or other fir…
Read More…A low profile add on board for the Flipper Zero to attach an ESP32 development board. It connects the power and serial lines of the Flipper to the ESP32 for use with Marauder or other firmware for the ESP32. It can also be used to flash firmware with the Flipper ESP flasher app. I have designed this for and tested it with ESP32 WROOM boards and it works great. Just solder on your board and clip the protruding header pins and it is good to go!
To simplify connecting an ESP32 to the Flipper in a small and compact way. I have seen a few ways to do this, but I thought I could take it a step further and make it even more compact.
Enter your email address if you'd like to be notified when Low Profile ESP32 Add On Board For Flipper Zero can be shipped to you:
While Tindie gives 14 days to ship, I try to ship orders same day or the next day. If I am running behind, I will message you.
As I work and am a student in addition to selling on Tindie, some packages may end up being dropped off later in the day and therefore received by the carrier the day after I drop them off.
International Orders
Any customs duties, fees, or VAT are the responsibility of the receiver.
Product: (3.50)
Documentation: (2.00)
David | Aug. 24, 2024
Scott | Sept. 2, 2023
$42.00
$4.80
$3.90
