Elektron (Octatrack) stand in 30° angle
Designed by Wesemane Industries in Germany
Wesemane Industries ES-30 Lift your Elektron (Octatrack) to new heights with the ES-30. The Elektron stand will hold your Elektron device in a 30° angle so you will not get back pain and your device …
Read More…Lift your Elektron (Octatrack) to new heights with the ES-30. The Elektron stand will hold your Elektron device in a 30° angle so you will not get back pain and your device will be much easier to play. You also prefer it when your synth or sampler is slightly angled? Get the ES-30!! It's a solid Wesemane Industries design made from medium-density fibreboard (MDF). As all other Wesemane Industries products this is open-source which means you don't necessarily have to pay me to get it. You can also pay other people to laser cut it for you (not recommended since I want to earn a few bucks) or DIY it (recommended and approved by Wesemane Industries). If you do so follow the link below to the Github repository and leave a <3. It contains all files (STL, dxf, illustrator) you need to DIY it. Thanks and relax and enjoy!
Width 0.5cm x Height 12.5cm x Length 18.5cm each
Eventhough the images show an Octatrack, it is not included! ://
Enter your email address if you'd like to be notified when ES-30 by Wesemane Industries can be shipped to you:
Refund only if product is damaged!
