Euroack aka modular synthesizer case made from medium-density fibreboard (MDF)
Designed by Wesemane Industries in GermanyNo shipping info available.
19" (84HP) Eurocase This product includes all MDF parts for a Eurorack (modular synthesizer) case. You will receive the parts disassembled, but you can follow the assembly instructions on the Weseman…
Read More…This product includes all MDF parts for a Eurorack (modular synthesizer) case. You will receive the parts disassembled, but you can follow the assembly instructions on the Wesemane Industries Github page to build it! It is very simple. All you need is a hotglue gun and you will be done in a few minutes. On Github it is explained how to finalize the case using rails, tapped strips and fixing brackets to build a case for your own modular synthesizer! Also feel free to contact me for power supply recommendations! Most Eurorack cases are very expensive, this is low-cost and still a solid design using medium-density fibreboard. There are also options to DIY this (if you have access to a laser cutter), see the DIY section in the Github profile to do so. All files are open-source! Enjoy!
Width x Height x Length = 46cm x 19cm x 17cm
Enter your email address if you'd like to be notified when 19" Eurocase by Wesemane Industries can be shipped to you:
Refund only if product is damaged!
$90.00
$175.00
