New Website https://www.sunshinecoastpedalcompany.com/ *The 'Stage Bro 2000' is a musicians best friend. During a live performance it provides artists an easy way to cue up and step through backing …
Read More…New Website https://www.sunshinecoastpedalcompany.com/
*The 'Stage Bro 2000' is a musicians best friend. During a live performance it provides artists an easy way to cue up and step through backing tracks while on stage. No longer will you need to rely on the sound guy to trigger your backing tracks! The Stage Bro is compact and cost efficient and great for touring bands.
Stage Bro is easy to use. Simply load your desired mp3/WAV audio files onto a USB Stick or microSD(microSD slot inside pedal). Insert the USB Stick into the Stage Bro and power it on, by plugging it in.
Use a 1/8" TRS patch cord to connect the Stage Bro to the PA system.
That's it, your done. you can now start stepping thru your backing tracks from on stage.
MP3s need to be rendered @: 256KBPS, 44100 Hz Or 192000 Hz sample freq
WAVs need to be rendered @: 16 BIT PCM, 44100 Hz sample freq (24 BIT PCM does not work) Other rendering settings may work but the above work for sure.
[Pro Tip: Most nightclub stages will have a few extra spare aux microphones setup on the stage. Just disconnect one of the microphones and plug this into Stage Bro using an adapter cable]
I am a musician, I built the first one for myself and my band. I wanted to have greater control over our live show. My band is small and local and cant rely on the sound guy to cue our backing tracks. we also couldn't afford more costly solutions like laptops with midi triggers. Also, time is a factor for tear down and setup during gigs. the Stage Bro is quick and simple.
-It is a unique solution to a common problem experienced by bands -It is the most cost effective solution in the market -It is built out of heavy duty and durable materials. It is a Stomp Box type Design! -It will look great with your other pedals!
1 x Stage Bro 2000 Stomp Box 1 x A/C power cord 1 x 8GB microSD card(preloaded with some public domain backing tracks) Note: for best performance use the microSD card. it will have much less latency compared to the USB thumb drive.
Enter your email address if you'd like to be notified when MP3/WAV Player Stomp Box "STAGE BRO 2000" can be shipped to you:
Product: (4.00)
Documentation: (4.25)
Shipping: (4.75)
Communication: (4.75)
Sanzone | June 20, 2021
Alvin | Aug. 22, 2019
Max | July 31, 2019
Michael | June 26, 2019
$92.00
